[postgis-users] Issue with the geometry field in postgresql tables
Vincent J. Troisi
Vincent.Troisi at Colorado.EDU
Mon Dec 18 07:13:33 PST 2006
We want to conduct searches on a table containing a variety of
geometry types. The search returns records that satisfy the
tests for intersection, containment, and overlap. Our DBA
has discovered an issue with using the geometry field; the
field can contain only one geometry definition.
Does anyone have an approach that we can use to query a
spatial field (e.g., geometry) in a table using the standard
functions available in postgis? See below...
> Here is the write up for the issue I found out with postGIS
> yesterday. The way postgresql handles the geometry column is that you
> have specify a spatial reference system ID everytime a geometry column
> is created. It then uses the spatial reference ID to enforce the rule
> that every geometry entered into that column matches the spatial
> reference ID or it will give you an error. It also allows postGIS to
> perform convertion on the projections. This causes the problem
> because we need to be able to assign different spatial reference ID to
> different datasets. With a fixed spatial reference ID assigned to the
> column, it prevents us from using that the column for datasets that
> have different spatial reference IDs.
