Hi Krishna, > I am using the Windows XP only. I have installed the postGIS with DCMMS > database in the windows workstation. In this case you'll be missing the UNIX shell. Which PostGIS/PostgreSQL version do you use? Where did you find the script, why do you think it should work for you? Regards, Steffen
