[postgis-users] Running post GIS script
kmohan
krishnamohan at dsmsoft.com
Thu Dec 28 20:39:29 PST 2006
I am using postGREsql 8.0. I have got the script from a client which merges
certain polygons and combines the attributes. I need to run this program to
perform that operation. Do you think I require Unix shell for windows in
this case.
Thanks and Regards,
Krishna Mohan
Steffen Macke wrote:
> Hi Krishna,
>> I am using the Windows XP only. I have installed the postGIS with DCMMS
>> database in the windows workstation.
> In this case you'll be missing the UNIX shell. Which PostGIS/PostgreSQL
> version
> do you use? Where did you find the script, why do you think it should
> work for you?
> Regards,
> Steffen
> postgis-users mailing list
View this message in context: http://www.nabble.com/Running-post-GIS-script-tf2889609.html#a8083852
Sent from the PostGIS - User mailing list archive at Nabble.com.
