[postgis-users] Adding Spatial Index to Existing Table
Brad Ediger
brad at bradediger.com
Fri Dec 29 11:18:15 PST 2006
If your lat/longs are WGS84, you should be able to say:
UPDATE table SET location = SetSRID(MakePoint(Long,Lat), 4326);
That should update all points in one statement, and set the proper SRID.
Brad
On Dec 29, 2006, at 1:08 PM, Adam wrote:
> This is my first try at adding spatial to my table. Currently I
> have a 'Lat' and 'Long' columns that have my Latitiude and Longitude.
> Do I need to add another column named 'Location' and insert each
> rows 'Lat' and 'Long' into the corresponding 'Location' row by
> doing: "INSERT INTO table ( Location ) VALUES ( GeometryFromText
> ('Point xx.xxx yy.yyyy', 4326) )" ? This will assume WGS 84 datum.
> Is this right?
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061229/a49caa57/attachment.html>
