[postgis-users] Adding Spatial Index to Existing Table
Adam adam at spatialsystems.org
Fri Dec 29 20:23:19 PST 2006
And when I add the new "location" column, do I add it as type "geometry"?
  ----- Original Message -----
  To: PostGIS Users Discussion
  Sent: Friday, December 29, 2006 1:18 PM
  Subject: Re: [postgis-users] Adding Spatial Index to Existing Table
  If your lat/longs are WGS84, you should be able to say:
  UPDATE table SET location = SetSRID(MakePoint(Long,Lat), 4326);
  That should update all points in one statement, and set the proper SRID.
  Brad
  On Dec 29, 2006, at 1:08 PM, Adam wrote:
    This is my first try at adding spatial to my table.  Currently I have a 'Lat' and 'Long' columns that have my Latitiude and Longitude.
    Do I need to add another column named 'Location' and insert each rows 'Lat' and 'Long' into the corresponding 'Location' row by doing:  "INSERT INTO table ( Location ) VALUES ( GeometryFromText('Point xx.xxx yy.yyyy', 4326) )" ?  This will assume WGS 84 datum.
    Is this right?
    postgis-users mailing list
    postgis-users at postgis.refractions.net
    http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061229/375b2b7e/attachment.html>
