[postgis-users] Failing: psql -d [yourdatabase] -f lwpostgis.sql
Matthew Perry perrygeo at gmail.com
Fri Dec 29 12:01:12 PST 2006
Adam,
 You may have to add the plpgsql language to your database first:
  createlang -d [yourdatabase] plpgsql
- matt
On 12/29/06, Adam <adam at spatialsystems.org> wrote:
> I'm installing version 1.1.6 and everything is fine until the step:
> It's all erroring out.  Any idea what the problem is or where I go to see
> what the error is?
> psql:lwpostgis.sql:3368: ERROR:  current transaction is aborted, commands
> ignored until end of transaction block
> psql:lwpostgis.sql:3375: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3380: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3385: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3444: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3462: ERROR:  current transaction is aborted, commands
> psql:lwpostgis.sql:3509: ERROR:  current transaction is aborted, commands
> ROLLBACK
> postgis-users mailing list
Matthew T. Perry
GIS Analyst / Software Engineer
National Center for Ecological Analysis and Synthesis (NCEAS)
work: perry at nceas.ucsb.edu
web: http://www.perrygeo.net
