[postgis-users] Failing: psql -d [yourdatabase] -f lwpostgis.sql
Adam
adam at spatialsystems.org
Fri Dec 29 19:45:38 PST 2006
I did createlang, here is my error:
[wohldad at localhost postgis-1.1.6]$
/usr/local/src/database/postgresql-8.1.3/src/bin/psql/psql -d gpsrd_v2 -f
lwpostgis.sql
BEGIN
psql:lwpostgis.sql:39: NOTICE: type "histogram2d" is not yet defined
DETAIL: Creating a shell type definition.
psql:lwpostgis.sql:39: ERROR: could not load library
"/usr/local/pgsql/lib/liblwgeom.so.1.1": libgeos_c.so.1: cannot open shared
object file: No such file or directory
psql:lwpostgis.sql:44: ERROR: current transaction is aborted, commands
ignored until end of transaction block
psql:lwpostgis.sql:52: ERROR: current transaction is aborted, commands
What I had to do to fix this is to add:
/usr/local/lib
to "/etc/ld.so.conf" and run "ldconfig".
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Friday, December 29, 2006 2:01 PM
Subject: Re: [postgis-users] Failing: psql -d [yourdatabase] -f
lwpostgis.sql
> Adam,
> You may have to add the plpgsql language to your database first:
> createlang -d [yourdatabase] plpgsql
> - matt
> On 12/29/06, Adam <adam at spatialsystems.org> wrote:
>> I'm installing version 1.1.6 and everything is fine until the step:
>> It's all erroring out. Any idea what the problem is or where I go to see
>> what the error is?
>> psql:lwpostgis.sql:3368: ERROR: current transaction is aborted, commands
>> psql:lwpostgis.sql:3375: ERROR: current transaction is aborted, commands
>> psql:lwpostgis.sql:3380: ERROR: current transaction is aborted, commands
>> psql:lwpostgis.sql:3385: ERROR: current transaction is aborted, commands
>> psql:lwpostgis.sql:3444: ERROR: current transaction is aborted, commands
>> psql:lwpostgis.sql:3462: ERROR: current transaction is aborted, commands
>> psql:lwpostgis.sql:3509: ERROR: current transaction is aborted, commands
>> ROLLBACK
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Matthew T. Perry
> GIS Analyst / Software Engineer
> National Center for Ecological Analysis and Synthesis (NCEAS)
> work: perry at nceas.ucsb.edu
> web: http://www.perrygeo.net
