[postgis-users] Adding Spatial Index to Existing Table
Adam
adam at spatialsystems.org
Fri Dec 29 20:57:10 PST 2006
I tried: UPDATE locations SET point_geom = SetSRID(makepoint('longitude','latitude'), 4326);
but got this error:
ERROR: invalid input syntax for type double precision: "longitude"Could the problem be that my "longitude" column is type "Character Varying"?----- Original Message -----
To: PostGIS Users Discussion
Sent: Friday, December 29, 2006 1:18 PM
Subject: Re: [postgis-users] Adding Spatial Index to Existing Table
If your lat/longs are WGS84, you should be able to say:
UPDATE table SET location = SetSRID(MakePoint(Long,Lat), 4326);
That should update all points in one statement, and set the proper SRID.
Brad
On Dec 29, 2006, at 1:08 PM, Adam wrote:
This is my first try at adding spatial to my table. Currently I have a 'Lat' and 'Long' columns that have my Latitiude and Longitude.
Do I need to add another column named 'Location' and insert each rows 'Lat' and 'Long' into the corresponding 'Location' row by doing: "INSERT INTO table ( Location ) VALUES ( GeometryFromText('Point xx.xxx yy.yyyy', 4326) )" ? This will assume WGS 84 datum.
Is this right?
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061229/98c1cc51/attachment.html>
