[postgis-users] Adding Spatial Index to Existing Table
Brad Ediger
brad at bradediger.com
Fri Dec 29 21:03:10 PST 2006
Don't put quotes around longitude and latitude. They are column names.
On Dec 29, 2006, at 10:57 PM, Adam wrote:
> I tried: UPDATE locations SET point_geom = SetSRID(makepoint
> ('longitude','latitude'), 4326);
> but got this error:
> ERROR: invalid input syntax for type double precision: "longitude"
> Could the problem be that my "longitude" column is type "Character
> Varying"?
> ----- Original Message -----
> From: Brad Ediger
> To: PostGIS Users Discussion
> Sent: Friday, December 29, 2006 1:18 PM
> Subject: Re: [postgis-users] Adding Spatial Index to Existing Table
> If your lat/longs are WGS84, you should be able to say:
> UPDATE table SET location = SetSRID(MakePoint(Long,Lat), 4326);
> That should update all points in one statement, and set the proper
> SRID.
> Brad
> On Dec 29, 2006, at 1:08 PM, Adam wrote:
>> This is my first try at adding spatial to my table. Currently I
>> have a 'Lat' and 'Long' columns that have my Latitiude and Longitude.
>> Do I need to add another column named 'Location' and insert each
>> rows 'Lat' and 'Long' into the corresponding 'Location' row by
>> doing: "INSERT INTO table ( Location ) VALUES ( GeometryFromText
>> ('Point xx.xxx yy.yyyy', 4326) )" ? This will assume WGS 84 datum.
>> Is this right?
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061229/313a239b/attachment.html>
