[postgis-users] Adding Spatial Index to Existing Table
Adam
adam at spatialsystems.org
Fri Dec 29 21:19:42 PST 2006
That worked and solved the problem. Thanks a lot!
Adam
----- Original Message -----
To: PostGIS Users Discussion
Sent: Friday, December 29, 2006 11:15 PM
Subject: Re: [postgis-users] Adding Spatial Index to Existing Table
You'll have to cast explicitly since your data are in varchars.
MakePoint(longitude::double precision, latitude::double precision)
should do the trick.
On Dec 29, 2006, at 11:08 PM, Adam wrote:
If I run without any quotes I get this error:
ERROR: function makepoint(character varying, character varying) does not exist
HINT: No function matches the given name and argument types. You may need to add explicit type casts.
If I run with double quotes I get this error:
Any other ideas as to what the problem is?
I looked up "MakePoint" in my functions and it is there:
Function Arguments Returns Programming language
makepoint double precision, double precision geometry c
Object File Link Symbol
$libdir/liblwgeom.so.1.1 LWGEOM_makepoint
Properties
IMMUTABLE
RETURNS NULL ON NULL INPUT
SECURITY INVOKER
----- Original Message ----- From: "Gregory S. Williamson" <gsw at globexplorer.com>
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>; "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Friday, December 29, 2006 11:02 PM
Subject: RE: [postgis-users] Adding Spatial Index to Existing Table
If you single quote something PostgreSQL will interpet it as a string ... since they are lower case anyway, try not quoting them at all, of double quote them if you need to preserve case:
UPDATE locations SET point_geom = SetSRID(makepoint(longitude,latitude), 4326);
Or:
UPDATE locations SET point_geom = SetSRID(makepoint("longitude","latitude"), 4326);
G
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net on behalf of Adam
Sent: Fri 12/29/2006 8:57 PM
Cc:
I tried: UPDATE locations SET point_geom = SetSRID(makepoint('longitude','latitude'), 4326);
but got this error:
ERROR: invalid input syntax for type double precision: "longitude"Could the problem be that my "longitude" column is type "Character Varying"?----- Original Message ----- From: Brad Ediger
Sent: Friday, December 29, 2006 1:18 PM
If your lat/longs are WGS84, you should be able to say:
UPDATE table SET location = SetSRID(MakePoint(Long,Lat), 4326);
That should update all points in one statement, and set the proper SRID.
Brad
On Dec 29, 2006, at 1:08 PM, Adam wrote:
This is my first try at adding spatial to my table. Currently I have a 'Lat' and 'Long' columns that have my Latitiude and Longitude.
Do I need to add another column named 'Location' and insert each rows 'Lat' and 'Long' into the corresponding 'Location' row by doing: "INSERT INTO table ( Location ) VALUES ( GeometryFromText('Point xx.xxx yy.yyyy', 4326) )" ? This will assume WGS 84 datum.
Is this right?
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
Click link below if it is SPAM gsw at globexplorer.com
"https://mailscanner.globexplorer.com/dspam/dspam.cgi?signatureID=4595f117132351789821027&user=gsw@globexplorer.com&retrain=spam&template=history&history_page=1"
!DSPAM:4595f117132351789821027!
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061229/6ece71a9/attachment.html>
