[postgis-users] Adding Spatial Index to Existing Table
Brad Ediger brad at bradediger.com
Fri Dec 29 21:15:33 PST 2006
You'll have to cast explicitly since your data are in varchars.
MakePoint(longitude::double precision, latitude::double precision)
should do the trick.
On Dec 29, 2006, at 11:08 PM, Adam wrote:
> If I run without any quotes I get this error:
> ERROR:  function makepoint(character varying, character varying)
> does not exist
> HINT:  No function matches the given name and argument types. You
> may need to add explicit type casts.
> If I run with double quotes I get this error:
> does not exist
> Any other ideas as to what the problem is?
> I looked up "MakePoint" in my functions and it is there:
>      Function Arguments Returns Programming language
>      makepoint double precision, double precision geometry c
>      Object File Link Symbol
>      $libdir/liblwgeom.so.1.1 LWGEOM_makepoint
>      Properties
>      IMMUTABLE
>      RETURNS NULL ON NULL INPUT
>      SECURITY INVOKER
> ----- Original Message ----- From: "Gregory S. Williamson"
> <gsw at globexplorer.com>
> To: "PostGIS Users Discussion" <postgis-
> users at postgis.refractions.net>; "PostGIS Users Discussion" <postgis-
> Sent: Friday, December 29, 2006 11:02 PM
> Subject: RE: [postgis-users] Adding Spatial Index to Existing Table
> If you single quote something PostgreSQL will interpet it as a
> string ... since they are lower case anyway, try not quoting them
> at all, of double quote them if you need to preserve case:
> UPDATE locations SET point_geom = SetSRID(makepoint
> (longitude,latitude), 4326);
> Or:
> ("longitude","latitude"), 4326);
> G
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net on behalf of Adam
> Sent: Fri 12/29/2006 8:57 PM
> To: PostGIS Users Discussion
> Cc:
> Subject: Re: [postgis-users] Adding Spatial Index to Existing Table
> I tried: UPDATE locations SET point_geom = SetSRID(makepoint
> ('longitude','latitude'), 4326);
> but got this error:
> ERROR:  invalid input syntax for type double precision:
> "longitude"Could the problem be that my "longitude" column is type
> "Character Varying"?-----  Original Message -----  From: Brad Ediger
>  Sent: Friday, December 29, 2006 1:18 PM
>  If your lat/longs are WGS84, you should be able to say:
>  UPDATE table SET location = SetSRID(MakePoint(Long,Lat), 4326);
>  That should update all points in one statement, and set the proper
> SRID.
>  Brad
>  On Dec 29, 2006, at 1:08 PM, Adam wrote:
>    This is my first try at adding spatial to my table.  Currently I
> have a 'Lat' and 'Long' columns that have my Latitiude and Longitude.
>    Do I need to add another column named 'Location' and insert each
> rows 'Lat' and 'Long' into the corresponding 'Location' row by
> doing:  "INSERT INTO table ( Location ) VALUES ( GeometryFromText
> ('Point xx.xxx yy.yyyy', 4326) )" ?  This will assume WGS 84 datum.
>    Is this right?
>    _______________________________________________
>    postgis-users mailing list
>    postgis-users at postgis.refractions.net
>    http://postgis.refractions.net/mailman/listinfo/postgis-users
> Click link below if it is SPAM gsw at globexplorer.com
> "https://mailscanner.globexplorer.com/dspam/dspam.cgi?
> signatureID=4595f117132351789821027&user=gsw at globexplorer.com&retrain=
> spam&template=history&history_page=1"
> !DSPAM:4595f117132351789821027!
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061229/d38bc1a0/attachment.html>
