[postgis-users] Adding Spatial Index to Existing Table
Adam adam at spatialsystems.org
Fri Dec 29 21:08:38 PST 2006
If I run without any quotes I get this error:
ERROR:  function makepoint(character varying, character varying) does not
exist
HINT:  No function matches the given name and argument types. You may need
to add explicit type casts.
If I run with double quotes I get this error:
exist
Any other ideas as to what the problem is?
I looked up "MakePoint" in my functions and it is there:
      Function Arguments Returns Programming language
      makepoint double precision, double precision geometry c
      Object File Link Symbol
      $libdir/liblwgeom.so.1.1 LWGEOM_makepoint
      Properties
      IMMUTABLE
      RETURNS NULL ON NULL INPUT
      SECURITY INVOKER
----- Original Message -----
From: "Gregory S. Williamson" <gsw at globexplorer.com>
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>;
Sent: Friday, December 29, 2006 11:02 PM
Subject: RE: [postgis-users] Adding Spatial Index to Existing Table
If you single quote something PostgreSQL will interpet it as a string ...
since they are lower case anyway, try not quoting them at all, of double
quote them if you need to preserve case:
UPDATE locations SET point_geom = SetSRID(makepoint(longitude,latitude),
4326);
Or:
UPDATE locations SET point_geom = SetSRID(makepoint("longitude","latitude"),
4326);
G
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net on behalf of Adam
Sent: Fri 12/29/2006 8:57 PM
To: PostGIS Users Discussion
Cc:
Subject: Re: [postgis-users] Adding Spatial Index to Existing Table
I tried: UPDATE locations SET point_geom =
SetSRID(makepoint('longitude','latitude'), 4326);
but got this error:
ERROR:  invalid input syntax for type double precision: "longitude"Could the
problem be that my "longitude" column is type "Character Varying"?-----
  Sent: Friday, December 29, 2006 1:18 PM
  If your lat/longs are WGS84, you should be able to say:
  UPDATE table SET location = SetSRID(MakePoint(Long,Lat), 4326);
  That should update all points in one statement, and set the proper SRID.
  Brad
  On Dec 29, 2006, at 1:08 PM, Adam wrote:
    This is my first try at adding spatial to my table.  Currently I have a
'Lat' and 'Long' columns that have my Latitiude and Longitude.
    Do I need to add another column named 'Location' and insert each rows
'Lat' and 'Long' into the corresponding 'Location' row by doing:  "INSERT
INTO table ( Location ) VALUES ( GeometryFromText('Point xx.xxx yy.yyyy',
4326) )" ?  This will assume WGS 84 datum.
    Is this right?
    postgis-users mailing list
    http://postgis.refractions.net/mailman/listinfo/postgis-users
Click link below if it is SPAM gsw at globexplorer.com
"https://mailscanner.globexplorer.com/dspam/dspam.cgi?signatureID=4595f117132351789821027&user=gsw@globexplorer.com&retrain=spam&template=history&history_page=1"
!DSPAM:4595f117132351789821027!
