[postgis-users] Error running lwpostgis.sql
Marshall, Steve
smarshall at wsi.com
Sat Dec 30 07:56:58 PST 2006
The 8.2 version of postgresql requires a "magic block" to be added to all plugin libraries. This ensures that you don't compile a plugin library with one version of postgresql, then load it into an incompatible version.
The magic block feature is new in 8.2, and did not exist in earlier versions of postgresql. I'm not sure if PostGIS 1.2 has support for adding a magic block (it seems from your error like it does not), so PostGIS 1.2 may be incompatible with PostgreSQL 8.2.
You probably will need to either upgrade PostGIS or downgrade PostgreSQL. For easiest upgrade, look for a version in the 1.x lineage of PostGIS that touts support for PostgreSQL 8.2.
Steve
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net on behalf of kijato
Sent: Sat 12/30/2006 10:18 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Error running lwpostgis.sql
On 2006. December 29. 00.40, strk at refractions.net wrote:
> On Tue, Dec 19, 2006 at 12:09:37PM +0100, Kis János Tamás wrote:
> > I'd like to use postgresql-8.2.0, geos-2.2.3, proj-4.4.9, but I
> > get the next message when I run the
> > "psql -U postgres gis < lwpostgis.sql" command:
> > ERROR: incompatible library
> > "/usr/local/pgsql/lib/liblwgeom.so.1.2": missing magic block
> Which PostGIS version ?
The PostGIS version is 1.2.0.
I don't understand why incompatible the liblwgeom library, because I
installed these programs in my home and wasn't error.
I think I have a very very small misstake, but what?
thx,
kjt
____________________________________________________________________
Év végi akció a FreeStartnál! Rendeljen most ADSL-t 2 évre, és az elsö 500 megrendelönek
egz év teljes havidíját elengedjük. Részleteket keresse a www.freestart.hu oldalon!
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061230/6c45d1ab/attachment.bin>
