[postgis-users] Tools Support Postgis
Gustavo Henrique Sberze Ribas
gribas at cpqd.com.br
Wed Feb 1 02:34:53 PST 2006
Hello,
Try using the CVS version. I'm using it with deeJump and PG 8.0 and it's
working fine (read only).
Gustavo
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of
> Barend Köbben
> Sent: Wednesday, February 01, 2006 5:49 AM
> To: PostGIS Users Discussion
> Subject: RE: [postgis-users] Tools Support Postgis
> Hi Ezequias,
> I know about the pluginon the PostGIS site, but that is (as
> it says on the site) "This driver currently only works with
> JUMP 1.1 and PostgreSQL <= 7.4."... As I (And many others)
> are now using PostGreSQL 8 and higher, it's not of much use.
> Barend Köbben
> International Institute for Geo-information
> Sciences and Earth Observation (ITC)
> PO Box 6, 7500AA Enschede (The Netherlands)
> ph: +31 (0)53 4874253; fax: +31 (0)53 4874335
> > [mailto:postgis-users-bounces at postgis.refractions.net] On
> > Behalf Of Ezequias Rodrigues da Rocha
> > Sent: 31 January 2006 20:22
> > Subject: Re: [postgis-users] Tools Support Postgis
> > The Plugin is on the PostGIS website (postgis.org) down
> right the
> > homepage.
> > There is another file I need to find out where it was posted.
> > Barend Köbben escreveu:
> > > So, where can I find that plugin. On the page
> > (http://openjump.org/wiki/show/Plugins) it says "PostGIS
> > database connector (read only)" but there is no link...?
> > > Barend Köbben
> > > [PS] for consideration of you and/or your colleagues:
> > > ITC is searching a Professor of Geodata Management and
> Engineering
> > > more details: http://www.itc.nl/about_itc/vacancies/2005_010.asp
> > >> Sent: 31 January 2006 19:47
> > >> It support Read only Postgis via PlugIn.
> > >> Sincerely
> > >> Ezequias
> > >> Matthew Perry escreveu:
> > >>> Ezequias,
> > >>> Does OpenJUMP actually support postgis? Last time I
> checked the
> > >>> postgis plugin only worked with JUMP 1.1 and older versions of
> > >>> postgres.
> > >>> matt
> > >>> On 1/31/06, Ezequias Rodrigues da Rocha
> > >> <ezequias at recife.pe.gov.br> wrote:
> > >>>> I would like someone put the OpenJUMP url and name on the
> > >> the wiki page
> > >>>> precisely at:
> > >> http://postgis.refractions.net/support/wiki/index.php?ToolsSup
> > >> portPostgis
> > >>>> Where JUMP and no Links
> > >>>> Why not put [OpenJUMP | www.openjump.org] ?
> > >>>> Sincerely
> > >>>> http://ezequiasrocha.blogspot.com
> > >>>> msn:ezequias at hotmail.com
> > >>>> "the worst of democracies is still better than the best of
> > >> dictatorship"
> > >>>> _______________________________________________
> > >>>> postgis-users mailing list
> > >>>> postgis-users at postgis.refractions.net
> > >>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> > >>> Matt Perry
> > >>> perrygeo at gmail.com
> > >>> http://www.perrygeo.net
> > >> dictatorship"
> > dictatorship"
