[postgis-users] Compatibility with PostgreSQL 8.1.2
Stephen Davies sdc at sdc.com.au
Wed Feb 1 14:29:32 PST 2006
FWIW, I have successfully built PostGIS 1.1.0 with 8.1.2 without any
hassles.
However, I always build from source tarballs; never from RPMs.
Cheers,
Stephen Davies
On Thursday 02 February 2006 06:30,
postgis-users-request at postgis.refractions.net wrote:
> Re: [postgis-users] Compatibility with PostgreSQL 8.1.2
>  From: "Bert Hinrichs" <a.hinrichs1 at comcast.net>
>  To: "PostGIS Users Discussion"
> <postgis-users at postgis.refractions.net>
> ----- Original Message -----
> From: "Frank Koormann" <frank.koormann at intevation.de>
> <postgis-users at postgis.refractions.net> Sent: Monday, January 30,
> 2006 10:33 PM
> Subject: Re: [postgis-users] Compatibility with PostgreSQL 8.1.2
> > Bert,
> > * Bert Hinrichs <a.hinrichs1 at comcast.net> [060131 05:32]:
> >>    I successfully download, installed, and set up PostgreSQL 8.1.2
> >> for Fedora
> >>    Core 4 from rpms.
> >>    I attempted to use the PosgGIS 1.1.0 rpms.  It did a sort of
> >> half-a$$ed
> >>    install (read that somethings installed and some didn't),
> > To improve the packages it would be helpful to know where the
> > packages are from and what problems you actually encountered.
> The PostgreSQL packages came from:
> http://www.postgresql.org/ftp/binary/v8.1.2/linux/rpms/fedora/fedora-
>core-4/
> these packages have names like:
> postgresql-8.1.2-1PGDG.i686.rpm rather than having the typical fc4
> kind of label I see on the rpms for the 8.0.6 versions currently at
> fedora/redhat sites.
> The PostGis packages came from:
> http://postgis.refractions.net/rpms/fedora/fedora-core-4/
> The problem was a Failed Dependency on PostgreSQL 8.1.1.  PostgreSQL
> 8.1.2 is installed.
> From the Yum screen:
> --> Processing Dependency: postgresql = 8.1.1 for package: postgis
> --> Finished Dependency Resolution
> Error: Missing Dependency: postgresql = 8.1.1 is needed by package
> postgis
> >>    Everything I've read keeps coming back to build from the
> >> source, but to do
> >>    that, it appears that you cannot have installed PostgreSQL from
> >> a binary
> >>    rpm.  It seems that you have to have built PostgreSQL from a
> >> source rpm
> >>    because it appears that I have to unpack the tarball into a
> >> contrib source
> >>    tree.
> >>    Is this true?
> > No. Since PostGIS 1.1.0 you only need the PostgreSQL development
> > packages and can run configure with the
> > --with-pgsql=<FULL PATH to pg_config>
> Ok, but I assume that it would still take the srpm versions of the
> PostgreSQL development packages rather than the binary rpm versions
> of the development packages and it would still require a build of the
> source code of PostGis and a manual install taking the management of
> PostGIS out from under the typical yum tool.  Correct? Does the
> PostGIS build environment have an uninstall capability in case it
> needed to be removed?
> Sorry if these seem like simple or stupid questions, but I may have
> to set up and manage about 7 of these installations.
This email is for the person(s) identified above, and is confidential to
the sender and the person(s).  No one else is authorised to use or
disseminate this email or its contents.
Stephen Davies Consulting                            Voice: 08-8177 1595
Adelaide, South Australia.                             Fax: 08-8177 0133
Computing & Network solutions.                       Mobile:0403 0405 83
