[postgis-users] Calculate driving distance in postgis
strk at refractions.net strk at refractions.net
Fri Feb 3 04:50:30 PST 2006
On Fri, Feb 03, 2006 at 01:42:37PM +0100, Daniel wrote:
> Basically, pgDijkstra is a postgresql extension to compute shortests
> paths in any graph (not only geographical ones)
> What's your idea ? (I'm not sure I really understand what u mean)
Things like returning a shortest-path LineString given two
Node IDS, for example.
Actually postgis currently just has a draft implementation
of the ISO topology model. This will likely require implementation
of the ISO network topology model instead (where connections
are explicit).
--strk;
