[postgis-users] changing a non spatial table to a spatial talble
Stephen Woodbridge woodbri at swoodbridge.com
Fri Feb 3 10:36:17 PST 2006
Kirk R. Wythers wrote:
> I am new to postgis. I am running GRASS GIS with a a postgresql
> attribute table which contains x,y coordinates and point data. I  would
> like to see if I could get this table spatially indexed. I have  postgis
> installed, but no geometry columns inserted yet.
> Can I alter a column that holds at UTM coordinate from double  precision
> to geometry, or should I add a new spatial columns for the  x and y's
> and then copy them into the new column?
> This is one of those, "I want to change a non spatial table to a
> spatial table" questions? Can I alter this table in any way, or  should
> I start over?
You should do something like:
select
addgeometrycolumn('your_schema','your_table','the_geom',<srid_for_your_utm_zone>,2);
update your_table set the_geom=setsrid(makepoint(<x_column>,
<y_column>), <srid_for_your_utm_zone>);
CREATE INDEX <your_index_name> ON your_table USING gist (the_geom);
vacuum analyze your_table;
-Steve W.
