[postgis-users] changing a non spatial table to a spatial talble
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Feb 3 11:37:29 PST 2006
Kirk R. Wythers wrote:
>>> I am new to postgis. I am running GRASS GIS with a a postgresql
>>> attribute table which contains x,y coordinates and point data. I
>>> would like to see if I could get this table spatially indexed. I
>>> have postgis installed, but no geometry columns inserted yet.
>>> Can I alter a column that holds at UTM coordinate from double
>>> precision to geometry, or should I add a new spatial columns for the
>>> x and y's and then copy them into the new column?
>>> This is one of those, "I want to change a non spatial table to a
>>> spatial table" questions? Can I alter this table in any way, or
>>> should I start over?
>> You should do something like:
>> select
>> addgeometrycolumn('your_schema','your_table','the_geom',<srid_for_your_utm_zone>,2);
>> update your_table set the_geom=setsrid(makepoint(<x_column>,
>> <y_column>), <srid_for_your_utm_zone>);
>> CREATE INDEX <your_index_name> ON your_table USING gist (the_geom);
>> vacuum analyze your_table;
> Thanks for the reply Steve. Two questions:
> 1. What is 'the_geometry'? Is this just a column name to hold the
> geometry or is it something specific. For the table in question, I have
> x,y coordinates. So are you talking about something like wtk_geom (for
> text bases geometery)?
the_geom is just the name of the geometry column. It can be anything but
I always call it the same so it is obvious where it is.
> 2. where do I find srids? I am in utm zone 15. Looks like those are in
> spatial_ref_sys?
From the proj epsg file it is likely one of these. the SRID would be
the first number in <>, ie: 2027 for the first entry below. You should
probably verify these with the values int the spatial reference system
table.
# NAD27(76) / UTM zone 15N
<2027> +proj=utm +zone=15 +ellps=clrk66 +units=m +no_defs <>
# Pulkovo 1995 / Gauss-Kruger 15N
<20075> +proj=tmerc +lat_0=0 +lon_0=87 +k=1.000000 +x_0=500000 +y_0=0
+ellps=krass +units=m +no_defs <>
# Beijing 1954 / Gauss-Kruger 15N
<21475> +proj=tmerc +lat_0=0 +lon_0=87 +k=1.000000 +x_0=500000 +y_0=0
# NAD27 / UTM zone 15N
<26715> +proj=utm +zone=15 +ellps=clrk66 +datum=NAD27 +units=m +no_defs <>
# NAD83 / UTM zone 15N
<26915> +proj=utm +zone=15 +ellps=GRS80 +datum=NAD83 +units=m +no_defs <>
# NAD27 / BLM 15N (ftUS)
<32065> +proj=tmerc +lat_0=0 +lon_0=-93 +k=0.999600
+x_0=500000.001016002 +y_0=0 +ellps=clrk66 +datum=NAD27
+to_meter=0.3048006096012192 +no_defs <>
# NAD27 / BLM 15N (feet)
<32075> +proj=tmerc +lat_0=0 +lon_0=-93 +k=0.999600
# WGS 72 / UTM zone 15N
<32215> +proj=utm +zone=15 +ellps=WGS72 +units=m +no_defs <>
# WGS 72BE / UTM zone 15N
<32415> +proj=utm +zone=15 +ellps=WGS72 +towgs84=0,0,1.9,0,0,0.814,-0.38
# WGS 84 / UTM zone 15N
<32615> +proj=utm +zone=15 +ellps=WGS84 +datum=WGS84 +units=m +no_defs <>
> 3. ok... 3 questions, what does the 2 at the end of the select statement
> refer to? Is that x and y?
The 2 means dimension = 2, ie X,Y. This is all documented in the postGIS
reference manual which can be found on the postGIS site.
> postgis-users mailing list
