[postgis-users] PostGIS, 64 bit Solaris, Invalide memory alloc message using force_collection
strk at refractions.net
Fri Feb 3 19:40:55 PST 2006
On Fri, Feb 03, 2006 at 07:08:50PM -0700, Michael Fuhr wrote:
> On Fri, Feb 03, 2006 at 09:54:08PM +0100, strk at refractions.net wrote:
> > Ok, please try again. --strk;
> lwgeom/lwgparse.c still includes stdint.h so the Solaris 9 build
> fails. Also, builds on Solaris 9 and FreeBSD 6.0 (and probably
> other systems) fail with the following error due to int4 being
> defined in both a PostgreSQL header and in wktparse.h:
> In file included from lwgeom_pg.c:8:
> wktparse.h:26: error: conflicting types for 'int4'
> [...]/include/server/c.h:360: error: previous declaration of 'int4' was here
> If a file includes postgres.h then it'll get a typedef for int4 so
> wktparse.h shouldn't also define it, but if wktparse.h doesn't
> define it then all files that need int4 will need to include
> postgres.h (some currently don't). I'd send a patch that makes
> everything work but I'm not sure which way you want to go: do you
> want PostGIS to define int4 or do you want to get it from PostgreSQL?
> Is there a reason to use int4 at all instead of int32_t or uint32_t?
No reason, we can use uint32_t and forget about int4.
Thanks for the help, my head is about to blow up!
--strk;
