[postgis-users] Spatial intersect optimization
Bill Binko
bill at binko.net
Mon Feb 6 14:44:46 PST 2006
Ack Small error below
Here's the correct select:
select a.name, sum(p.area) as parcel_area
from polygons a, parcels p
where a.the_geom && Centroid(p.the_geom)
and contains(a.the_geom, Centroid(p.the_geom))
group by a.name
order by parcel_area;
Bill Binko wrote:
> You absolutely need GiST indexes for this to run effectively.
> Two additional things you could do for both sanity and performance:
> 1) Run the query on Centroids instead of actual areas. You can do
> this two ways, but in addition to being faster, it is actually more
> accurate since your parcels will only fall within one of your polygons.
> a) Create a separate table or column that holds the results of the
> Centroid() function
> b) Easier: Create a functional index like so:
> CREATE INDEX cent_idx on parcels USING GIST (Centroid(the_geom)
> GIST_GEOMETRY_OPS);
> Then you would write the query below as:
> and contains(a.the_geom, p.the_geom)
> group by a.name
> 2) If this is your main use for the tables, you can try ordering your
> data by Clustering: read the archives of this list for a long
> discussion on whether or not it actually helps (but it does :)
> CLUSTER cent_idx on parcels;
> Hope this helps
> Stephen Woodbridge wrote:
>> Josh,
>> select a.name, sum(p.area) a parcel_area
>> where a.the_geom && p.the_geom
>> and intersects(a.the_geom, p.the_geom)
>> group by a.name
>> There is not much more you can do to make this faster. If parcels can
>> overlap polygons and you want only the part of the parcel that is in
>> the polygon then you will want the intersection of the two and then
>> you will need to compute the area for the intersection, etc.
>> -Steve W.
>> Josh Livni wrote:
>>> I am fairly inexperienced with optimizing spatial queries in
>>> PostGIS, and am trying to do something similar to the example
>>> 4.6.2.4 in the documentation at
>>> http://postgis.refractions.net/docs/ch04.html
>>> It notes that this will be slow due to summarizing. I have over
>>> 500k parcels, and I'd like to do some summary stats in each of about
>>> 15k polygons.
>>> My question is, could the example mentioned above become faster if
>>> it took better advantage of the gist indices? or is it already?
>>> How would I go about adding some kind of 'AND the_geom && (bbox of
>>> m.geom)' to the WHERE clause?
>>> Thanks for any hints,
>>> -Josh
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
