[postgis-users] Help urgently needed - geomfromEWKT() / PostGIS on Mac OS X
Blair Zajac
blair at orcaware.com
Thu Feb 9 20:55:51 PST 2006
On Feb 9, 2006, at 6:42 PM, Christian Heine wrote:
> Hey Blair,
>> Why don't you use use Fink's or DarwinPort's Postgresql/Postgis
>> builds instead?
>> The Fink postgresql81 package includes Postgis, and DarwinPorts'
>> has a separate postgis package.
> I know, I don't like the strange way how fink installs things in
> the /sw directory. It's hard to keep track of those things and
> often fink lags a couple of versions behind the current releases.
> Think of the GMT4 distro through fink. Plus sometime you want to
> build some extras which is - I guess - not that easy with a fink
> install.
> Don't have any experience with DarwinPorts.
Both DarwinPort and Fink use a privately maintained directory tree to
manage, so that'll be something to get over. DarwinPorts uses /opt/
local by default. They do that so they can manage all the files in
there, unlike with /usr/local, which is a dumping ground.
DarwinPort does seem to keep the packages more up to date than Fink.
DarwinPorts is completely up to date I believe in Postgresql and
Postgis.
If I want a custom package, I just use what the packaging system
provides and tweak it for my use. It saves a lot of time and effort
in building everything myself.
Regards,
Blair
Blair Zajac, Ph.D.
CTO, OrcaWare Technologies
<blair at orcaware.com>
Subversion training, consulting and support
http://www.orcaware.com/svn/
