[postgis-users] How to get the size of a postgis table ?
Aaron Koning
aaronkoning at gmail.com
Tue Feb 14 15:37:54 PST 2006
Number of rows in the table:
SELECT count(*) FROM <table_name>;
Size of files on disk - Method 1:
- SELECT relpages * 8192 AS size_in_bytes FROM pg_class WHERE relnamespace
= (SELECT oid FROM pg_namespace WHERE nspname = '<schema_name>') AND relname
= '<table_name>'
- Note: This value is only updated by the commands VACUUM, ANALYZE, and
CREATE INDEX.
Size of files on disk - Method 2:
- Run this command to find the file node number for a particular table:
SELECT relfilenode FROM pg_class WHERE relnamespace = (SELECT oid
FROM pg_namespace WHERE nspname = '<schema_name>') AND relname =
'<table_name>'
- Then run ls -l <your postgres data directory>/base/<file node number>
Example: ls -l /usr/local/pgsql/data/base/17384
Aaron
On 2/14/06, Ezequias Rodrigues da Rocha <ezequias at recife.pe.gov.br> wrote:
> Hi list,
> I would like to know how to get the size of a postgis table ? I did a
> upload of a shapefile into postgis but I am not certain of the size of it.
> I am worried becouse I need about 10 minutes to load a 6mb shapefile on
> a WFS service.
> Sincerely...
> http://ezequiasrocha.blogspot.com
> msn:ezequias at hotmail.com
> "the worst of democracies is still better than the best of dictatorship"
> postgis-users mailing list
| Aaron Koning
| Information Technologist
| Prince George, BC, Canada.
| http://datashare.gis.unbc.ca/fist/
| http://datashare.gis.unbc.ca/gctp-js/
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060214/bb6e4db7/attachment.html>
