[postgis-users] How to create a geographic view
Ezequias Rodrigues da Rocha ezequias at recife.pe.gov.br
Wed Feb 15 08:43:38 PST 2006
I create a view with all attributes but with a subset of the main layer.
It still does not appears on  the geoserver.
I am worried about it yet.
Could you tell me if is possible to make an export to PostGIS by using
only Java ?
Ezequias
Nicolas Ribot escreveu:
>> Hi list,
>> I was trying to create a view of my map to access a wfs services. The
>> problem is that we couldn't see it at Geoserver why ?
>> Becouse I did a PostgreSQL view of my map.
>> I need to know how to make a new postgis table view based on a existed
>> postgis table.
>> Any suggestion would be glad.
>> Sincerely...
> Hi,
> You should be able to create your view from your gis table, then
> updating the geometry_columns table to add information about this view
> to allow external programs to be aware of this geographic view.
> Use an insert command like this one to add a new entry in geometry_columns:
> insert into geometry_columns
> (f_table_schema, f_table_catalog, f_table_name, f_geometry_column,
> srid, type, coord_dimension)
> values
> ('', '', 'my_view', 'the_geom', <my_srid>, 'GEOMETRY', 2);
> It worked, for example, in OpenJump.
> Nicolas
> postgis-users mailing list
http://ezequiasrocha.blogspot.com
msn:ezequias at hotmail.com
"the worst of democracies is still better than the best of dictatorship"
