[postgis-users] Partitioning spatial table
Arnaud Lesauvage
thewild at freesurf.fr
Fri Feb 17 06:46:26 PST 2006
Hi Markus, thanks for your answer !
Markus Schaber a écrit :
>>From my personal experience, 5 million rows do not yet justify
> partitioning, especially on road data, which usually is write once and
> then read-only.
Actually, it was just for the benefit of the constraint exclusion
that I wanted to try this.
> Which indices did you put on the table? (send us the output of psql
> command "\d tablename").
The table has many columns, so I spare them (frc, i.e. the
road-class, is a smallint).
Index :
«nw_pkey» PRIMARY KEY, btree (gid)
«nw_frc_btree» btree (frc)
«nw_nw_geometry_gist» gist (nw_geometry)
> Have you recently VACUUMed and ANALYZed the table?
Yes, and the data never changes (has you said in your post, it is
a write once - read many dataset).
> Could you send us the output of "EXPLAIN ANALYZE <your query>;"? If
> estimations and reality are very different, increasing the statistics
> target will help.
Sure !
"Index Scan using nw_nw_geometry_gist on nw (cost=0.00..6.02
rows=1 width=141)"
" Index Cond: ('<the box>'::geometry && nw_geometry)"
" Filter: ((frc = 2) AND ('<the box>'::geometry && nw_geometry))"
Reality is ~5 minutes.
But I don't know what you mean by increasing the statistics (sorry
for my lack of knowledge, I am new to postgresql, I am moving from
mysql).
> If you don't have NULL geometries, add a NOT NULL constraint to your
> geometry column and CLUSTER your table on the geometry index.
I'll check the nullity of geometries, I am not sure of this.
How do you cluster a table on an index (again, sorry but these
concepts are unkown in the mysql world...)
> You may also want to use partial indices in addition to the full one, e. G.
That sound very good to me !
I usually filter data on both the road class AND the geometry
location, so it definitively makes sense to filter on both !
I'll try this ASAP !
Thanks again Markus !
Regards
Arnaud
