[postgis-users] create spatial table problem
Tyler Mitchell
tylermitchell at shaw.ca
Tue Feb 21 09:35:19 PST 2006
Looks like oids may not be turned on by default for your database?
Tyler
----- Original Message -----
From: "Kralidis,Tom [Burlington]" <Tom.Kralidis at ec.gc.ca>
Date: Tuesday, February 21, 2006 9:20 am
Subject: RE: [postgis-users] create spatial table problem
> Thanks for the advice. This worked when I indexed on id instead
> of oid.
> Thanks
> ..Tom
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net
> > [postgis-users-bounces at postgis.refractions.net] On
> > Behalf Of Robert Burgholzer
> > Sent: Tuesday, February 21, 2006 12:17 PM
> > To: PostGIS Users Discussion
> > The problem does not seem to be your spatial table per se, it
> > is your trying to create an index on OID, which it seems not
> > to like. Since you are creating a serial column, id, why not
> > index on that? (Or is that what you were trying to do and got a
> typo?)>
> > r.b.
> > Behalf Of Kralidis,Tom [Burlington]
> > Sent: Tuesday, February 21, 2006 12:10 PM
> > To: postgis-users
> > Subject: [postgis-users] create spatial table problem
> > Hi,
> > I'm trying to create a spatial table with:
> > create table hydromet_stations (
> > id serial primary key,
> > stnid text,
> > portfurl text,
> > graphurl text,
> > sensormlurl text,
> > organization text
> > select
> > AddGeometryColumn('hydromet_stations','the_geom',4326,'POINT',2);
> > create index hydromet_stations_idx ON hydromet_stations USING
> > GIST ( the_geom GIST_GEOMETRY_OPS ); create index
> > hydromet_stations_idx_oid ON hydromet_stations ( oid );
> > ...which gives me an error:
> > devgeodb2=# \i create_table2.sql
> > psql:create_table2.sql:9: NOTICE: CREATE TABLE will create
> > implicit sequence "hydromet_stations_id_seq" for seri al
> > column "hydromet_stations.id"
> > psql:create_table2.sql:9: NOTICE: CREATE TABLE / PRIMARY KEY
> > will create implicit index "hydromet_stations_pkey" for
> > table "hydromet_stations" CREATE TABLE
> > addgeometrycolumn
> > public.hydromet_stations.the_geom SRID:4326 TYPE:POINT
> > DIMS:2 geometry_column fixed:0 (1 row)
> > CREATE INDEX
> > psql:create_table2.sql:14: ERROR: column "oid" does not
> > exist devgeodb2=# delete from geometry_columns where
> > f_table_name = 'hydromet_stations'; DELETE 1 devgeodb2=# drop
> > table hydromet_stations ;
> > devgeodb2=# select postgis_version();
> > postgis_version
> > 1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
> > (1 row)
> > Any advice would be much appreciated.
> > Thanks
> > ..Tom
> > postgis-users mailing list postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
