[postgis-users] create spatial table problem
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Tue Feb 21 09:38:51 PST 2006
Not sure. I do know that we moved the entire database (via pg_dumpall)
and inserted via psql -f <file> as we moved things across servers.
Everything else seems to be there (PostGIS enabled MapServer apps work).
Maybe the oid thing has to be turned on? I do know we have these
defined for our previous spatial tables. How would one enable this?
..Tom
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Tyler Mitchell
> Sent: Tuesday, February 21, 2006 12:35 PM
> To: PostGIS Users Discussion
> Subject: Re: RE: [postgis-users] create spatial table problem
> Looks like oids may not be turned on by default for your database?
> Tyler
> ----- Original Message -----
> From: "Kralidis,Tom [Burlington]" <Tom.Kralidis at ec.gc.ca>
> Date: Tuesday, February 21, 2006 9:20 am
> Subject: RE: [postgis-users] create spatial table problem
> > Thanks for the advice. This worked when I indexed on id instead
> > of oid.
> > Thanks
> > ..Tom
> > > [postgis-users-bounces at postgis.refractions.net] On
> > > Behalf Of Robert Burgholzer
> > > Sent: Tuesday, February 21, 2006 12:17 PM
> > > The problem does not seem to be your spatial table per se, it
> > > is your trying to create an index on OID, which it seems not
> > > to like. Since you are creating a serial column, id, why not
> > > index on that? (Or is that what you were trying to do and got a
> > typo?)>
> > > r.b.
> > > Behalf Of Kralidis,Tom [Burlington]
> > > Sent: Tuesday, February 21, 2006 12:10 PM
> > > To: postgis-users
> > > Subject: [postgis-users] create spatial table problem
> > > Hi,
> > > I'm trying to create a spatial table with:
> > > create table hydromet_stations (
> > > id serial primary key,
> > > stnid text,
> > > portfurl text,
> > > graphurl text,
> > > sensormlurl text,
> > > organization text
> > > select
> > > AddGeometryColumn('hydromet_stations','the_geom',4326,'POINT',2);
> > > create index hydromet_stations_idx ON hydromet_stations USING
> > > GIST ( the_geom GIST_GEOMETRY_OPS ); create index
> > > hydromet_stations_idx_oid ON hydromet_stations ( oid );
> > > ...which gives me an error:
> > > devgeodb2=# \i create_table2.sql
> > > psql:create_table2.sql:9: NOTICE: CREATE TABLE will create
> > > implicit sequence "hydromet_stations_id_seq" for seri al
> > > column "hydromet_stations.id"
> > > psql:create_table2.sql:9: NOTICE: CREATE TABLE / PRIMARY KEY
> > > will create implicit index "hydromet_stations_pkey" for
> > > table "hydromet_stations" CREATE TABLE
> > > addgeometrycolumn
> > > public.hydromet_stations.the_geom SRID:4326 TYPE:POINT
> > > DIMS:2 geometry_column fixed:0 (1 row)
> > > CREATE INDEX
> > > psql:create_table2.sql:14: ERROR: column "oid" does not
> > > exist devgeodb2=# delete from geometry_columns where
> > > f_table_name = 'hydromet_stations'; DELETE 1 devgeodb2=# drop
> > > table hydromet_stations ;
> > > devgeodb2=# select postgis_version();
> > > postgis_version
> > > 1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
> > > (1 row)
> > > Any advice would be much appreciated.
> > > Thanks
> > > ..Tom
> > > _______________________________________________
> > > postgis-users mailing list postgis-users at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
