[postgis-users] Partitioning - Create statements partitioning
Bernhard Reimar Hoefle
Bernhard.Hoefle at uibk.ac.at
Fri Feb 24 00:14:47 PST 2006
Hi Arnaud!
I'm interested in your last post on the PostGIS mailing list. Could you
please post to the mailing list how you created the tables and
indices for the partitioning.
I would like to partition a huge table with point geometries (>tens of millions)
with two geometry columns.
The check constraint should be a spatial query on a polygon where all points of
a "slave" table belong to. But the polygons can also overlap.
Can anyone suggest how to install such a table structure?
I want to try the following:
CREATE TABLE master (
id serial,
) WITHOUT OIDS;
SELECT AddGeometryColumn('public','master','geom_first',-1,'POINT',3);
SELECT AddGeometryColumn('public','master','geom_last',-1,'POINT',3);
CREATE TABLE slave1 ( ) INHERITS (master);
INSERT INTO geometry_columns
values('','public','slave1','geom_first',3,-1,'POINT');
values('','public','slave1','geom_last',3,-1,'POINT');
ALTER TABLE slave1 ADD PRIMARY KEY(id);
CREATE INDEX slave1_geom_first on slave1 USING GIST (geom_first
gist_geometry_ops);
CREATE INDEX slave1_geom_last on slave1 USING GIST (geom_last
gist_geometry_ops);
ALTER TABLE slave1 ADD CHECK(geom_first && 'POLYGON((32636721.9110775
5191166.84296152,32636275.2935075 5191560.08108307,32634869.5543309
5189963.52220268,32635316.1719008 5189570.28408112,32636721.9110775
5191166.84296152))'::GEOMETRY or geom_last && 'POLYGON((32636721.9110775
5191166.84296152))'::GEOMETRY);
CREATE TABLE slaveXX ( ) INHERITS (master);
A scan should only be done on tables where the requested spatial query (on
geom_first or geom_last) overlaps with the bounding box of the polygon. Better
would be if it overlaps with the polygon but I don't know if it reduces
performance. I want to test it.
Bernhard
