[postgis-users] point in polygon or equivalent
    Michael Fuhr
    mike at fuhr.org
    Mon Jan  2 20:01:09 PST 2006
On Mon, Jan 02, 2006 at 07:17:00PM -0800, Mark Wright wrote:
> What is the benefit to using the contains() or within() functions
> rather than the ~ operator? I've tested both and they give the same
> results in the same amount of time (plus or minus about 20
> miliseconds).
The operator checks bounding boxes; the function checks the
geometries themselves.  Example:
  |           | A
  |   |  |  | B
A's bounding box contains B's bounding box so A ~ B would be true,
but A doesn't actually contain B so contains(A, B) would be false.
Bounding box searches can use an index so they're a fast way to
find possible matches; the function identifies matches with certainty
but it's more expensive, especially for complex geometries, so you
want to avoid calling it when it's known that it will return false.
Michael Fuhr
