[postgis-users] point in polygon or equivalent
Darryl Watson
dwatson at roof-express.com
Tue Jan 3 08:07:08 PST 2006
Michael:
That is a very clear and excellent explanation of the differences
between the operator and function internals. Maybe that should go in
the wiki and/or FAQ and/or performance tips? Thanks!
Michael Fuhr wrote:
>On Mon, Jan 02, 2006 at 07:17:00PM -0800, Mark Wright wrote:
>>What is the benefit to using the contains() or within() functions
>>rather than the ~ operator? I've tested both and they give the same
>>results in the same amount of time (plus or minus about 20
>>miliseconds).
>The operator checks bounding boxes; the function checks the
>geometries themselves. Example:
> | | A
> | | | | B
>A's bounding box contains B's bounding box so A ~ B would be true,
>but A doesn't actually contain B so contains(A, B) would be false.
>Bounding box searches can use an index so they're a fast way to
>find possible matches; the function identifies matches with certainty
>but it's more expensive, especially for complex geometries, so you
>want to avoid calling it when it's known that it will return false.
Darryl Watson
Senior Software Developer
*Roof Express, LLC*
8310 South Valley Highway
Suite 300
Englewood, CO 80112
303.524.1193 (direct)
303.524.1101 (fax)
www.roof-express.com/ <http://www.roof-express.com/>
