[postgis-users] PostGIS 1.1.0: Windows Build Instructions - bugs reports -
david techer
davidtecher at yahoo.fr
Wed Jan 4 07:26:06 PST 2006
Hi Marc,
In France, few guyes haven't expected to build themselves on Win32 :-)
and helped me to correct my own doc:
They sent me errors and bugs
Error 1: (mea culpa! reported by Jamal BERRICH)
In my documentation, I did a mistake:
it is PGFELIBS="$(echo $(${PGCONFIG} --libdir)/libpq.dll)"
and not
PGFELIBS="$(echo $(${PG_CONFIG} --libdir)/libpq.dll)"
here it should be better I think to use the reports U mentionned in a
precedent mail :-) from "shell and bash"
on mingw/msys instead of my reports.
Error 2: (bug from libiconv dll reported by Alain FERCHAL)
If U used libiconv from
http://prdownloads.sourceforge.net/gnuwin32/libiconv-1.8-1-bin.zip?download
U might have this error when U do 'make' or 'make install'
"The procedure entry point libiconv_close could not be located in the dynamic link library libiconv-2.dll"
So first download
http://ovh.dl.sourceforge.net/sourceforge/gnuwin32/diffutils-2.8.7-1-dep.zip
then
Decompress it in C:\MinGW\bin then rename libiconv2.dll to libiconv-2.dll
Source info: see this link http://projects.edgewall.com/trac/ticket/2233
I haven't this error but it is interesting to tell it.
Hope these infos could be helpful.
Sincerely yours.
--david;
Jean David TECHER
e-mail: davidtecher(at)yahoo(dot)fr
site: http://techer.pascal.free.fr/postgis/
Mark Cave-Ayland a écrit :
>>-----Original Message-----
>>From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
>>bounces at postgis.refractions.net] On Behalf Of david techer
>>Sent: 01 January 2006 23:23
>>To: PostGIS Users Discussion; PostGIS Development Discussion
>>Subject: [postgis-users] PostGIS 1.1.0: Windows Build Instructions
>>(toimprove by someone)
>>Hi Marc and PostGISers,
>>Marc, I hope U will have a solution to correct the bug from MinGW before
>>your installer for 1.1.0 is ready.
>>I did a doc joined to this mail in docbook format and pdf format.
>>Since I'm not very good at English, I hope U will have a better idea to
>>improve it.
>>No problem if U want to modify it ;-) and put it somewhere in net or in
>>a wiki...
>>I hope it will be helpful for community even if it is not a great doc.
>>Sincerely yours,
>>--david;
>Hi David,
>Many thanks for your work on the documentation. I hope to improve this when
>I get some time so that it will be included as part of the distribution to
>help other building building under Win32.
>Kind regards,
>Mark.
>WebBased Ltd
>17 Research Way
>Plymouth
>PL6 8BT
>T: +44 (0)1752 797131
>F: +44 (0)1752 791023
>http://www.webbased.co.uk
>http://www.infomapper.com
>http://www.swtc.co.uk
>This email and any attachments are confidential to the intended recipient
>and may also be privileged. If you are not the intended recipient please
>delete it from your system and notify the sender. You should not copy it or
>use it for any purpose nor disclose or distribute its contents to any other
>person.
___________________________________________________________________________
Nouveau : téléphonez moins cher avec Yahoo! Messenger ! Découvez les tarifs exceptionnels pour appeler la France et l'international.
Téléchargez sur http://fr.messenger.yahoo.com
