[postgis-users] PostGIS 1.1.0: Windows Build Instructions (toimprove by someone)
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Wed Jan 4 01:55:22 PST 2006
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of david techer
> Sent: 01 January 2006 23:23
> To: PostGIS Users Discussion; PostGIS Development Discussion
> Subject: [postgis-users] PostGIS 1.1.0: Windows Build Instructions
> Hi Marc and PostGISers,
> Marc, I hope U will have a solution to correct the bug from MinGW before
> your installer for 1.1.0 is ready.
> I did a doc joined to this mail in docbook format and pdf format.
> Since I'm not very good at English, I hope U will have a better idea to
> improve it.
> No problem if U want to modify it ;-) and put it somewhere in net or in
> a wiki...
> I hope it will be helpful for community even if it is not a great doc.
> Sincerely yours,
> --david;
Hi David,
Many thanks for your work on the documentation. I hope to improve this when
I get some time so that it will be included as part of the distribution to
help other building building under Win32.
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
