[postgis-users] AddGeometryColumn() Question
Stephen Woodbridge woodbri at swoodbridge.com
Fri Jan 6 06:54:06 PST 2006
Hi all,
When a create a table using
CREATE TABLE foobar AS SELECT ...
SELECT * INTO TABLE foobar ...
The metadata and constraints that are created by AddGeometryColumn() are
not created.
What is the correct way to do this?
Can I use AddGeometryColumn() and specify the existing column in the new
table?
Does it have the smarts to check if it already exists and continue only
updating the missing information and constraints?
Would it make sense to make it behave like this? exactly for this purpose?
So many questions, so little time!
-Steve
