[postgis-users] AddGeometryColumn() Question
strk at refractions.net strk at refractions.net
Fri Jan 6 06:57:33 PST 2006
On Fri, Jan 06, 2006 at 09:54:06AM -0500, Stephen Woodbridge wrote:
> Hi all,
> When a create a table using
> CREATE TABLE foobar AS SELECT ...
> SELECT * INTO TABLE foobar ...
> The metadata and constraints that are created by AddGeometryColumn() are
> not created.
> What is the correct way to do this?
Create with AddGeometryColumn, then INSERT INTO .. SELECT .. FROM ..
> Can I use AddGeometryColumn() and specify the existing column in the new
> table?
Nope :(
> Does it have the smarts to check if it already exists and continue only
> updating the missing information and constraints?
No, it's dumb. I was thinking about this when working on topology support.
SQL/MM specs use a "santifier" function for this (read: use existing thing
making it a "special" thing), while AddGeometryColumn insists on creating
it.
> Would it make sense to make it behave like this? exactly for this purpose?
Good question, what other people think ?
--strk;
