[postgis-users] OT: pgsql2shp temporary table persists (avpgcon)
Robert Burgholzer rburghol at chesapeakebay.net
Fri Jan 6 11:02:02 PST 2006
I ran into a problem running avpgcon --I managed to goof up my db
somehow, I think cancelling a pgsql2shp query at a bad time. Although
this problem occurred using avpgcon, I believe that the source of the
problem may lie in the shp2pgsql routine somehow.
Now, when opening up the avpgcon add theme dialog a phantom table shows
up in the list named "__pgsql2shp_tmp_table". Whenever I try to load a
shape from this database it fails, and the postgres error console shows
it asking for one of the columns in this phantom table, regardless of
the table I am actually asking for.  This even happens when using
p2sql2shp from the command line regardless of the query I put in.  It
shows up in multiple clients (2 different workstations) and seems to
affect only this database. I can load things fine from other databases.
I have restarted my postmaster process to no avail, and am currently
performing a "vacuum full" in hopes that this will solve it.
I will report back if this solves the problem, but I am thinking this
may be an obscure bug in the shp2pgsql routine. Any clues?
thanks
Robert W. Burgholzer
Nonpoint Source Data Analyst
University of Maryland, College Park
Chesapeake Bay Program Office
410 Severn Avenue, Suite 305B
Annapolis, MD, 21403
Phone: (410) 267-5779
http://www.chesapeakebay.net/
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060106/fe883419/attachment.html>
