[postgis-users] Problems finding PostgresQL on an FC4 install ation
Putler, Dan
Dan.Putler at sauder.ubc.ca
Fri Jan 6 17:01:11 PST 2006
Hi Mike,
That did the trick. I had looked at the configure help, I just didn't
give it the full path to pg_config.
Dan
On 6-Jan-06, at 4:40 PM, Mike Leahy wrote:
> Dan,
> When I did this, I had set the pgsql parameter to point to
> 'pg_config', and this has usually been the requirement for most
> PostgreSQL-based builds that I done so far. If you run './
> configure --help', you should see this is mentioned in the info
> listed there. Below is the configuration I used (my pgsql is
> installed in /usr by the released RPMs for FC4), and I had no
> problems with the build.
> ./configure --prefix=/usr/local --with-pgsql=/usr/bin/pg_config --
> with-geos=/usr/local/bin/geos-config --with-proj=/usr/local
> Hope this helps,
> Mike
> Putler, Dan wrote:
>> Hi All,
>> I'm having a heck of a time installing PostGIS 1.1.0 on an FC4
>> system (with a P3 processor) that is running Postgresql 8.1.1,
>> GEOS 2.2.1, and Proj 4.4.9.
>> I installed Postgresql from source with /usr/local/pgsql as the
>> installation directory. As a result, I configured PostGIS using
>> the option --with-pgsql=/usr/local/pgsql (I've also tried /usr/
>> local and / usr/local/pgsql/bin as the postgres directories).
>> Things seem to go along fine with configure since it finds geos,
>> and proj, and doesn't complain about postgres. However, when I
>> become root and attempt make, bad things happen. I created a
>> transcript of the session, and here are the first few lines of
>> the output of the make process, which might provide a clue to my
>> problem:
>> make -C lwgeom
>> make[1]: execvp: /usr/local/pgsql: Permission denied
>> make[1]: Entering directory `/home/putler/build/postgresql-8.1.1/
>> contrib/postgis-1.1.0/lwgeom'
>> gcc -DUSE_VERSION=82 -DPOSTGIS_LIB_VERSION='"1.1.0"' -
>> DPOSTGIS_VERSION='"1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"' -
>> DPOSTGIS_SCRIPTS_VERSION='"1.1.0"' -
>> DPOSTGIS_BUILD_DATE='"2006-01-06 22:23:57"' -I/usr/local/include -
>> DUSE_PROJ -I -DAUTOCACHE_BBOX=1 - DUSE_STATS -Wall -g -O2 -fPIC -
>> fexceptions -DUSE_GEOS -I/usr/local/ include -c -o liblwgeom.o
>> liblwgeom.c
>> In file included from liblwgeom.c:26:
>> lwgeom_pg.h:4:22: error: postgres.h: No such file or directory
>> lwgeom_pg.h:5:29: error: utils/geo_decls.h: No such file or directory
>> lwgeom_pg.h:6:18: error: fmgr.h: No such file or directory
>> lwgeom_pg.h:28: error: syntax error before â
>> The three header files make can't find are part of postgres, so
>> my guess is make still can't find postgres. I've played with
>> LD_LIBRARY_PATH without any luck (which isn't surprising since it
>> doesn't point to the header directories). Any ideas about what
>> I'm not doing to make postgres visible?
>> Dan
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060106/769ed5ee/attachment.html>
