[postgis-users] Hw to Oracle dmp file to postgis /postgresql
Paul Ramsey
pramsey at refractions.net
Fri Jan 6 19:43:39 PST 2006
Bruce,
No, I am referring to the full edition of Oracle, that you can
download, as long as you use it for development purposes only.
<http://www.oracle.com/database/index.html> Note the "Free Download"
button to the right. <http://www.oracle.com/technology/software/
htdocs/devlic.html?http://www.oracle.com/technology/software/products/
database/oracle10g/htdocs/10201ppclinuxsoft.html>
I am not sure of the contents of your dump. If it's pretty generic
spatial, you could use a tool like FME to pull it out and stuff it
into PostGIS. If it's more custom, you might find that writing a few
lines of Java code to pull things out and dump them onto disk works
better.
Paul
On 6-Jan-06, at 11:20 AM, Clay, Bruce wrote:
> Paul:
> Thanks for your reply.
> When you say free, are you referring to Oracle Express? If I read the
> web page right, it is limited to 4 Gig database. The database I was
> given is approx 150 gig split into 32 gig chunks.
> Does this mean I am stuck with having to load it back into Oracle
> somewhere?
> I don't know Oracle or so this is likely a dumb question. If I can do
> that, how do I extract the maps to put into PostGis?
> Bruce
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Paul
> Ramsey
> Sent: Friday, January 06, 2006 12:24 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Hw to Oracle dmp file to postgis
> /postgresql
> Bruce,
> No, you are going to have to put it back into Oracle and then extract
> the information in a more portable form. Fortunately you can
> download Oracle for free for development purposes, so it is "merely"
> a matter of effort, not dollars.
> P
> On Jan 6, 2006, at 7:11 AM, Clay, Bruce wrote:
>> I have seen this question come up before on other forums but I can
>> not
>> find the answer.
>> I have received some Oracle DMP files containing several map
>> raster. Is
>> there any way to get PostGis / Postreqsl to import them?
>> I do not have any ASCII / SQL info with them.
>> Thanks for your help.
>> Bruce
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
