[postgis-users] clipping and dumping
strk at refractions.net
Mon Jan 9 07:59:52 PST 2006
The intersection consists in heterogeneous geometry types
(polygons and points maybe?) thus a geometrycollection
is returned.
Check summary() output to see what you got.
--strk;
On Tue, Jan 10, 2006 at 02:21:12AM +1100, Shoaib Burq wrote:
> Hi
> I'm fairly new to PostGIS. Am running the most recent PostGIS release
> with Postgres 8.1 on linux.
> I had a rather large shapefile (500MB) which I loaded into the PostGIS
> db using shp2pgsql. I want to now clip it using a bounding box to
> create a new geometry.
> I used the following query:
> CREATE TABLE cont25_a AS SELECT c.gid, c.version, c.igds_level,
> c.igds_color, c.as2482, c.height, c.sourced, c.sourcea, c.entity
> intersection( geomfromtext(
> 'POLYGON((140.864607446442 -36.1766451540338,
> 150.146522341991 -36.1766451540338,
> 150.146522341991 -33.904044258012,
> 140.864607446442 -33.904044258012,
> 140.864607446442 -36.1766451540338))'), c.the_geom) AS the_geom,
> FROM cont25tbl AS c;
> Firstly is this query correct? It appears to have worked successfully.
> When I try to dump the clipped geometry using pgsql2shp I get the
> following error:
> $ pgsql2shp CFA cont25_a -f cont25_a
> Initializing... type 'GEOMETRYCOLLECTION' is not Supported at this time.
> The DBF file will be created but not the shx or shp files.
> You've found a bug! (pgsql2shp.c:2708)
> Unfortunately I can't connect to the db using a tool like uDig or QGIS
> due to firewall restrictions.
> Also, what's the diff between this geometrycollection and the geometry column?
> - sb
> postgis-users mailing list
/"\ ASCII Ribbon Campaign
\ / Respect for low technology.
X Keep e-mail messages readable by any computer system.
/ \ Keep it ASCII.
