[postgis-users] adding new shape data in existing PostGIS table
Emily Gouge
egouge at refractions.net
Mon Jan 9 11:38:45 PST 2006
Try using the -a option in the shp2pgsql.
So instead of
/usr/local/pgsql/bin/shp2pgsql forest forest | /usr/local/pgsql/bin/psql -a forestrydb
try
/usr/local/pgsql/bin/shp2pgsql -a forest forest | /usr/local/pgsql/bin/psql forestrydb
Also you can write the output of the shp2pgsql comment to a file instead of the database and try
looking at the beginning of the file. If you use the -a option there should be no create table
statement at the beginning of the file, without the -a option there should be a create table statement.
Emily
Kefyalew Sahle wrote:
> Hello,
> I have got problem in adding new data in a table that already exist in PostGIS.
> I used the following command
> I received the following message
> ERROR: relation "forest" already exists ...............
> ERROR: current transaction is aborted, commands ignored until end of transaction block
> When running without any options. The task is aborted. The following is the massage displayed after running the shp2pgsql command:
> Shapefile type: Polygon
> Postgis type: MULTIPOLYGON[2]
> BEGIN
> NOTICE: CREATE TABLE will create implicit sequence "forest_gid_seq1" for serial column "forest.gid"
> ROLLBACK
> Would you please provide me some information how I can append in my existing PostGIS
> database new data that is available in shape format?
> Thanks in advance
> Kef
> Yahoo! Photos
> Ring in the New Year with Photo Calendars. Add photos, events, holidays, whatever.
> postgis-users mailing list
