[postgis-users] adding new shape data in existing PostGIS table
Kefyalew Sahle
kefyalew_sahle at yahoo.com
Tue Jan 10 03:54:06 PST 2006
Dear Emily Gouge and Michael Fuhr ,
Thank you very much for your advice. I have used the option you mentioned and it has worked very well.
the databse name is forestrydb
the schema name is forest
the existing PostGIS table name to which the old data is located is forest
the new shape file is forest3.shp
the command used is
/usr/local/pgsql/bin/shp2pgsql -a forest3.shp forest.forest | /usr/local/pgsql/bin/psql forestrydb
it works very well.
Thank you again for your support.
Kefyalew
Emily Gouge <egouge at refractions.net> wrote: Try using the -a option in the shp2pgsql.
So instead of
/usr/local/pgsql/bin/shp2pgsql forest forest | /usr/local/pgsql/bin/psql -a forestrydb
try
/usr/local/pgsql/bin/shp2pgsql -a forest forest | /usr/local/pgsql/bin/psql forestrydb
Also you can write the output of the shp2pgsql comment to a file instead of the database and try
looking at the beginning of the file. If you use the -a option there should be no create table
statement at the beginning of the file, without the -a option there should be a create table statement.
Emily
Kefyalew Sahle wrote:
> Hello,
> I have got problem in adding new data in a table that already exist in PostGIS.
> I used the following command
> I received the following message
> ERROR: relation "forest" already exists ...............
> ERROR: current transaction is aborted, commands ignored until end of transaction block
> When running without any options. The task is aborted. The following is the massage displayed after running the shp2pgsql command:
> Shapefile type: Polygon
> Postgis type: MULTIPOLYGON[2]
> BEGIN
> NOTICE: CREATE TABLE will create implicit sequence "forest_gid_seq1" for serial column "forest.gid"
> ROLLBACK
> Would you please provide me some information how I can append in my existing PostGIS
> database new data that is available in shape format?
> Thanks in advance
> Kef
> Yahoo! Photos
> Ring in the New Year with Photo Calendars. Add photos, events, holidays, whatever.
> postgis-users mailing list
Yahoo! Photos
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060110/9869ab9f/attachment.html>
