[postgis-users] Query planner problems
Don Drake don at drakeconsult.com
Mon Jan 9 12:59:42 PST 2006
You're correct about the standalone statement, I thought the query plan was
from your function call.  Sorry about that.
You have the wrong index type:
CREATE INDEX city_gist ON swoodbridge.city USING btree (the_geom);
You don't want btree, you want gist.
-Don
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Stephen
Woodbridge
Sent: Monday, January 09, 2006 2:40 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Query planner problems
Don Drake wrote:
> Try recompiling the procedure, I believe the query plan is cached.
How? but just running the create or replace again?
But that will have no impact on the standalone select statement that I
can not get to use the index.
-Steve
> -Don
Stephen
> Woodbridge
> Sent: Monday, January 09, 2006 2:27 PM
> Subject: [postgis-users] Query planner problems
> Hi all,
> I'm trying to create a pgpsql function to spatially assign the nearest
> city in a table to a point.
> CREATE OR REPLACE
> FUNCTION swoodbridge.get_closest_city(  public.geometry,   float8)
> RETURNS int4 AS
> $BODY$
>    declare
>      pnt   alias for $1;
>      miles alias for $2;
>      dist  float;
>      cid   integer;
>    begin
>      if pnt is null then
>        return 0;
>      end if;
>      dist = swoodbridge.miles_to_degree(miles, 0.0);
>      select city_id into cid from swoodbridge.city t_in where
> expand(pnt, dist) && t_in.the_geom
>        order by distance_sphere(pnt, t_in.the_geom) asc limit 1;
>      if not found then
>        return 0;
>      else
>        return cid;
>      end if;
>    end;
> $BODY$
> LANGUAGE 'plpgsql' VOLATILE;
> But it is working horridly slow. I extracted the select and just add
> constants of "pnt" so I could run explain on it. I can not get it to use
> the gist index on the table.
> select city_id from swoodbridge.city t_in
>    where t_in.the_geom && expand(setsrid(makepoint(0,0),4326), 10)
>    order by distance_sphere(setsrid(makepoint(0,0),4326), t_in.the_geom)
>      asc limit 1;
>>Limit  (cost=166074.43..166074.43 rows=1 width=29)
>>  ->  Sort  (cost=166074.43..166215.21 rows=56314 width=29)
>>        Sort Key:
distance_sphere('0101000020E610000000000000000000000000000000000000'::geomet
> ry, the_geom)
>>        ->  Seq Scan on city t_in  (cost=0.00..160699.25 rows=56314
> width=29)
>>              Filter: (the_geom &&
'0103000020E6100000010000000500000000000000000024C000000000000024C0000000000
00024C0000000000000244000000000000024400000000000002440000000000000244000000
> 000000024C000000000000024C000000000000024C0'::geometry)
> It has the following gist index and it has been vacuum analyzed.
> Is there some way to force it to use the index?
> -Steve
> postgis-users mailing list
