[postgis-users] postgis installation on current Postgresql (8.1) database (on Debian)
Assad Jarrahian jarraa at gmail.com
Wed Jan 11 23:28:25 PST 2006
hey david and all,
   thanks for replying.
I tried the first step and it raised an exception
sudo apt-get postgresql-dev
E: Invalid operation postgresql-dev
I googled and did not find much.
Can you help me out. If you tell me what info to look at (give you), I
can do that.
thanks.
-assad
On 1/11/06, TECHER David <davidtecher at yahoo.fr> wrote:
> You need postgresql headers files in order to compil postgis
> so do
> then install geos
> wget http://geos.refractions.net/geos-2.2.1.tar.bz2
> tar xvjf geos-2.2.1.tar.bz2
> cd geos-2.2.1
> ./configure && make && make install
> do the same for proj 4.49
> wget ftp://ftp.remotesensing.org/proj/proj-4.4.9.tar.gz
> tar xvzf ...
> download postgis-1.1.0.tar.gz
> untar it
> then install it (./configure;make;make install)
> Assad Jarrahian a écrit :
> >Hello,
> >   I have postgres version 8.1 installed via apt-get and have a
> >database already up and running. I wanted to add the distance
> >functions and the rest of postgis capabilities to it. I am not sure
> >how to go about installing postgis and giving the db access to it
> >without disrupting much.
> >Any help would be appreciated.
> >-assad
> >p.s> I also cannot seem to find the contrib drectory to put the
> >install tar under.
> >_______________________________________________
> >postgis-users mailing list
> >postgis-users at postgis.refractions.net
> >http://postgis.refractions.net/mailman/listinfo/postgis-users
> ___________________________________________________________________________
> Nouveau : téléphonez moins cher avec Yahoo! Messenger ! Découvez les tarifs exceptionnels pour appeler la France et l'international.
> Téléchargez sur http://fr.messenger.yahoo.com
