[postgis-users] postgis installation on current Postgresql (8.1) database (on Debian)
Assad Jarrahian
jarraa at gmail.com
Thu Jan 12 00:46:17 PST 2006
David and all,
Thanks. I got everything installed, but when installing postgis I
got errors (see below).
The configure summary:
SUMMARY
HOST_OS: linux-gnu
PGSQL: /usr/bin/pg_config
GEOS: /usr/local/bin/geos-config (with C-API)
PROJ: dir=/usr/local
ICONV: 1
PORTNAME: linux
PREFIX: /usr
EPREFIX: ${prefix}
DOC: /usr/share/doc/postgresql-doc-8.1
DATA: /usr/share/postgresql/8.1/postgresql/contrib
MAN: /usr/share/postgresql/8.1/man
BIN: /usr/lib/postgresql/8.1/bin
EXT: /usr/lib/postgresql/8.1/lib (\$$libdir)
and the errors:
lwgeom_pg.h:28: warning: type defaults to 'int' in declaration of
'getGeometryOID'
lwgeom_pg.h:28: warning: data definition has no type or storage class
lwgeom_pg.h:35: error: syntax error before '*' token
lwgeom_pg.h:36: error: syntax error before 'box2df_to_box'
lwgeom_pg.h:36: warning: type defaults to 'int' in declaration of
'box2df_to_box'
lwgeom_pg.h:36: warning: data definition has no type or storage class
lwgeom_pg.h:37: error: syntax error before 'BOX'
lwgeom_pg.h:40: error: syntax error before 'BOX2D_same'
lwgeom_pg.h:40: warning: type defaults to 'int' in declaration of 'BOX2D_same'
lwgeom_pg.h:40: warning: parameter names (without types) in function declaration
lwgeom_pg.h:40: warning: data definition has no type or storage class
lwgeom_pg.h:41: error: syntax error before 'BOX2D_overlap'
lwgeom_pg.h:41: warning: type defaults to 'int' in declaration of
'BOX2D_overlap'
lwgeom_pg.h:41: warning: parameter names (without types) in function declaration
lwgeom_pg.h:41: warning: data definition has no type or storage class
lwgeom_pg.h:42: error: syntax error before 'BOX2D_overleft'
lwgeom_pg.h:42: warning: type defaults to 'int' in declaration of
'BOX2D_overleft'
lwgeom_pg.h:42: warning: parameter names (without types) in function declaration
lwgeom_pg.h:42: warning: data definition has no type or storage class
lwgeom_pg.h:43: error: syntax error before 'BOX2D_left'
lwgeom_pg.h:43: warning: type defaults to 'int' in declaration of 'BOX2D_left'
lwgeom_pg.h:43: warning: parameter names (without types) in function declaration
lwgeom_pg.h:43: warning: data definition has no type or storage class
lwgeom_pg.h:44: error: syntax error before 'BOX2D_right'
lwgeom_pg.h:44: warning: type defaults to 'int' in declaration of 'BOX2D_right'
lwgeom_pg.h:44: warning: parameter names (without types) in function declaration
lwgeom_pg.h:44: warning: data definition has no type or storage class
lwgeom_pg.h:45: error: syntax error before 'BOX2D_overright'
lwgeom_pg.h:45: warning: type defaults to 'int' in declaration of
'BOX2D_overright'
lwgeom_pg.h:45: warning: parameter names (without types) in function declaration
lwgeom_pg.h:45: warning: data definition has no type or storage class
lwgeom_pg.h:46: error: syntax error before 'BOX2D_overbelow'
lwgeom_pg.h:46: warning: type defaults to 'int' in declaration of
'BOX2D_overbelow'
lwgeom_pg.h:46: warning: parameter names (without types) in function declaration
lwgeom_pg.h:46: warning: data definition has no type or storage class
lwgeom_pg.h:47: error: syntax error before 'BOX2D_below'
lwgeom_pg.h:47: warning: type defaults to 'int' in declaration of 'BOX2D_below'
lwgeom_pg.h:47: warning: parameter names (without types) in function declaration
lwgeom_pg.h:47: warning: data definition has no type or storage class
lwgeom_pg.h:48: error: syntax error before 'BOX2D_above'
lwgeom_pg.h:48: warning: type defaults to 'int' in declaration of 'BOX2D_above'
lwgeom_pg.h:48: warning: parameter names (without types) in function declaration
lwgeom_pg.h:48: warning: data definition has no type or storage class
lwgeom_pg.h:49: error: syntax error before 'BOX2D_overabove'
lwgeom_pg.h:49: warning: type defaults to 'int' in declaration of
'BOX2D_overabove'
lwgeom_pg.h:49: warning: parameter names (without types) in function declaration
lwgeom_pg.h:49: warning: data definition has no type or storage class
lwgeom_pg.h:50: error: syntax error before 'BOX2D_contained'
lwgeom_pg.h:50: warning: type defaults to 'int' in declaration of
'BOX2D_contained'
lwgeom_pg.h:50: warning: parameter names (without types) in function declaration
lwgeom_pg.h:50: warning: data definition has no type or storage class
lwgeom_pg.h:51: error: syntax error before 'BOX2D_contain'
lwgeom_pg.h:51: warning: type defaults to 'int' in declaration of
'BOX2D_contain'
lwgeom_pg.h:51: warning: parameter names (without types) in function declaration
lwgeom_pg.h:51: warning: data definition has no type or storage class
lwgeom_pg.h:52: error: syntax error before 'BOX2D_intersects'
lwgeom_pg.h:52: warning: type defaults to 'int' in
lwgeom_pg.h:69: error: syntax error before 'LWGEOM_getBBOX'
lwgeom_pg.h:69: warning: type defaults to 'int' in declaration of
'LWGEOM_getBBOX'
lwgeom_pg.h:69: warning: parameter names (without types) in function declaration
lwgeom_pg.h:69: warning: data definition has no type or storage class
lwgeom_pg.h:70: error: syntax error before 'LWGEOM_addBBOX'
lwgeom_pg.h:70: warning: type defaults to 'int' in declaration of
'LWGEOM_addBBOX'
lwgeom_pg.h:70: warning: parameter names (without types) in function declaration
lwgeom_pg.h:70: warning: data definition has no type or storage class
lwgeom_pg.h:71: error: syntax error before 'LWGEOM_dropBBOX'
lwgeom_pg.h:71: warning: type defaults to 'int' in declaration of
'LWGEOM_dropBBOX'
lwgeom_pg.h:71: warning: parameter names (without types) in function declaration
lwgeom_pg.h:71: warning: data definition has no type or storage class
liblwgeom.c: In function 'trim_trailing_zeros':
liblwgeom.c:158: warning: implicit declaration of function 'strchr'
liblwgeom.c:158: warning: incompatible implicit declaration of
built-in function 'strchr'
liblwgeom.c:163: warning: implicit declaration of function 'strlen'
liblwgeom.c:163: warning: incompatible implicit declaration of
built-in function 'strlen'
make[1]: *** [liblwgeom.o] Error 1
make: *** [liblwgeom] Error 2
On 1/12/06, Stefano Costa <steko at iosa.it> wrote:
> Il giorno gio, 12/01/2006 alle 00.28 -0700, Assad Jarrahian ha scritto:
> > hey david and all,
> > thanks for replying.
> > I tried the first step and it raised an exception
> > sudo apt-get postgresql-dev
> > E: Invalid operation postgresql-dev
> You should add an "install" just like this:
> sudo apt-get install postgresql-dev
> Regards,
> Stefano
> Stefano Costa
> http://www.iosa.it Software Open Source per l'Archeologia
> Jabber: steko at jabber.linux.it
> GnuPG Key ID 1024D/0xD0D30245
> Linux Registered User #385969 counter.li.org
> postgis-users mailing list
