[postgis-users] postgis installation on current Postgresql (8.1) database (on Debian)
strk at refractions.net
Thu Jan 12 08:15:08 PST 2006
Please show some more lines - starting right before the *first*
warning during make - after a make clean.
--strk;
On Thu, Jan 12, 2006 at 08:39:25AM -0700, Assad Jarrahian wrote:
> I am talking about the latest release 1.10
> Yes it seems that I can find postgres.h
> pg_config --includedir-server
> /usr/include/postgresql/8.1/server
> What should I do with it?
> thanks.
> -assad
> On 1/12/06, strk at refractions.net <strk at refractions.net> wrote:
> > You're talking about postgis version ?
> > Can you find postgres.h under `/usr/bin/pg_config --includedir-server` ?
> > --strk;
> > On Thu, Jan 12, 2006 at 01:46:17AM -0700, Assad Jarrahian wrote:
> > > David and all,
> > > Thanks. I got everything installed, but when installing postgis I
> > > got errors (see below).
> > > The configure summary:
> > > SUMMARY
> > > HOST_OS: linux-gnu
> > > PGSQL: /usr/bin/pg_config
> > > GEOS: /usr/local/bin/geos-config (with C-API)
> > > PROJ: dir=/usr/local
> > > ICONV: 1
> > > PORTNAME: linux
> > > PREFIX: /usr
> > > EPREFIX: ${prefix}
> > > DOC: /usr/share/doc/postgresql-doc-8.1
> > > DATA: /usr/share/postgresql/8.1/postgresql/contrib
> > > MAN: /usr/share/postgresql/8.1/man
> > > BIN: /usr/lib/postgresql/8.1/bin
> > > EXT: /usr/lib/postgresql/8.1/lib (\$$libdir)
> > > and the errors:
> > > lwgeom_pg.h:28: warning: type defaults to 'int' in declaration of
> > > 'getGeometryOID'
> > > lwgeom_pg.h:28: warning: data definition has no type or storage class
> > > lwgeom_pg.h:35: error: syntax error before '*' token
> > > lwgeom_pg.h:36: error: syntax error before 'box2df_to_box'
> > > lwgeom_pg.h:36: warning: type defaults to 'int' in declaration of
> > > 'box2df_to_box'
> > > lwgeom_pg.h:36: warning: data definition has no type or storage class
> > > lwgeom_pg.h:37: error: syntax error before 'BOX'
> > > lwgeom_pg.h:40: error: syntax error before 'BOX2D_same'
> > > lwgeom_pg.h:40: warning: type defaults to 'int' in declaration of 'BOX2D_same'
> > > lwgeom_pg.h:40: warning: parameter names (without types) in function declaration
> > > lwgeom_pg.h:40: warning: data definition has no type or storage class
> > > lwgeom_pg.h:41: error: syntax error before 'BOX2D_overlap'
> > > lwgeom_pg.h:41: warning: type defaults to 'int' in declaration of
> > > 'BOX2D_overlap'
> > > lwgeom_pg.h:41: warning: parameter names (without types) in function declaration
> > > lwgeom_pg.h:41: warning: data definition has no type or storage class
> > > lwgeom_pg.h:42: error: syntax error before 'BOX2D_overleft'
> > > lwgeom_pg.h:42: warning: type defaults to 'int' in declaration of
> > > 'BOX2D_overleft'
> > > lwgeom_pg.h:42: warning: parameter names (without types) in function declaration
> > > lwgeom_pg.h:42: warning: data definition has no type or storage class
> > > lwgeom_pg.h:43: error: syntax error before 'BOX2D_left'
> > > lwgeom_pg.h:43: warning: type defaults to 'int' in declaration of 'BOX2D_left'
> > > lwgeom_pg.h:43: warning: parameter names (without types) in function declaration
> > > lwgeom_pg.h:43: warning: data definition has no type or storage class
> > > lwgeom_pg.h:44: error: syntax error before 'BOX2D_right'
> > > lwgeom_pg.h:44: warning: type defaults to 'int' in declaration of 'BOX2D_right'
> > > lwgeom_pg.h:44: warning: parameter names (without types) in function declaration
> > > lwgeom_pg.h:44: warning: data definition has no type or storage class
> > > lwgeom_pg.h:45: error: syntax error before 'BOX2D_overright'
> > > lwgeom_pg.h:45: warning: type defaults to 'int' in declaration of
> > > 'BOX2D_overright'
> > > lwgeom_pg.h:45: warning: parameter names (without types) in function declaration
> > > lwgeom_pg.h:45: warning: data definition has no type or storage class
> > > lwgeom_pg.h:46: error: syntax error before 'BOX2D_overbelow'
> > > lwgeom_pg.h:46: warning: type defaults to 'int' in declaration of
> > > 'BOX2D_overbelow'
> > > lwgeom_pg.h:46: warning: parameter names (without types) in function declaration
> > > lwgeom_pg.h:46: warning: data definition has no type or storage class
> > > lwgeom_pg.h:47: error: syntax error before 'BOX2D_below'
> > > lwgeom_pg.h:47: warning: type defaults to 'int' in declaration of 'BOX2D_below'
> > > lwgeom_pg.h:47: warning: parameter names (without types) in function declaration
> > > lwgeom_pg.h:47: warning: data definition has no type or storage class
> > > lwgeom_pg.h:48: error: syntax error before 'BOX2D_above'
> > > lwgeom_pg.h:48: warning: type defaults to 'int' in declaration of 'BOX2D_above'
> > > lwgeom_pg.h:48: warning: parameter names (without types) in function declaration
> > > lwgeom_pg.h:48: warning: data definition has no type or storage class
> > > lwgeom_pg.h:49: error: syntax error before 'BOX2D_overabove'
> > > lwgeom_pg.h:49: warning: type defaults to 'int' in declaration of
> > > 'BOX2D_overabove'
> > > lwgeom_pg.h:49: warning: parameter names (without types) in function declaration
> > > lwgeom_pg.h:49: warning: data definition has no type or storage class
> > > lwgeom_pg.h:50: error: syntax error before 'BOX2D_contained'
> > > lwgeom_pg.h:50: warning: type defaults to 'int' in declaration of
> > > 'BOX2D_contained'
> > > lwgeom_pg.h:50: warning: parameter names (without types) in function declaration
> > > lwgeom_pg.h:50: warning: data definition has no type or storage class
> > > lwgeom_pg.h:51: error: syntax error before 'BOX2D_contain'
> > > lwgeom_pg.h:51: warning: type defaults to 'int' in declaration of
> > > 'BOX2D_contain'
> > > lwgeom_pg.h:51: warning: parameter names (without types) in function declaration
> > > lwgeom_pg.h:51: warning: data definition has no type or storage class
> > > lwgeom_pg.h:52: error: syntax error before 'BOX2D_intersects'
> > > lwgeom_pg.h:52: warning: type defaults to 'int' in
> > > lwgeom_pg.h:69: error: syntax error before 'LWGEOM_getBBOX'
> > > lwgeom_pg.h:69: warning: type defaults to 'int' in declaration of
> > > 'LWGEOM_getBBOX'
> > > lwgeom_pg.h:69: warning: parameter names (without types) in function declaration
> > > lwgeom_pg.h:69: warning: data definition has no type or storage class
> > > lwgeom_pg.h:70: error: syntax error before 'LWGEOM_addBBOX'
> > > lwgeom_pg.h:70: warning: type defaults to 'int' in declaration of
> > > 'LWGEOM_addBBOX'
> > > lwgeom_pg.h:70: warning: parameter names (without types) in function declaration
> > > lwgeom_pg.h:70: warning: data definition has no type or storage class
> > > lwgeom_pg.h:71: error: syntax error before 'LWGEOM_dropBBOX'
> > > lwgeom_pg.h:71: warning: type defaults to 'int' in declaration of
> > > 'LWGEOM_dropBBOX'
> > > lwgeom_pg.h:71: warning: parameter names (without types) in function declaration
> > > lwgeom_pg.h:71: warning: data definition has no type or storage class
> > > liblwgeom.c: In function 'trim_trailing_zeros':
> > > liblwgeom.c:158: warning: implicit declaration of function 'strchr'
> > > liblwgeom.c:158: warning: incompatible implicit declaration of
> > > built-in function 'strchr'
> > > liblwgeom.c:163: warning: implicit declaration of function 'strlen'
> > > liblwgeom.c:163: warning: incompatible implicit declaration of
> > > built-in function 'strlen'
> > > make[1]: *** [liblwgeom.o] Error 1
> > > make: *** [liblwgeom] Error 2
> > > On 1/12/06, Stefano Costa <steko at iosa.it> wrote:
> > > > Il giorno gio, 12/01/2006 alle 00.28 -0700, Assad Jarrahian ha scritto:
> > > > > hey david and all,
> > > > > thanks for replying.
> > > > > I tried the first step and it raised an exception
> > > > > sudo apt-get postgresql-dev
> > > > > E: Invalid operation postgresql-dev
> > > > You should add an "install" just like this:
> > > > sudo apt-get install postgresql-dev
> > > > Regards,
> > > > Stefano
> > > > Stefano Costa
> > > > http://www.iosa.it Software Open Source per l'Archeologia
> > > > Jabber: steko at jabber.linux.it
> > > > GnuPG Key ID 1024D/0xD0D30245
> > > > Linux Registered User #385969 counter.li.org
> > > > _______________________________________________
> > > > postgis-users mailing list
> > > > postgis-users at postgis.refractions.net
> > > > http://postgis.refractions.net/mailman/listinfo/postgis-users
> > /"\ ASCII Ribbon Campaign
> > \ / Respect for low technology.
> > X Keep e-mail messages readable by any computer system.
> > / \ Keep it ASCII.
/ \ Keep it ASCII.
