[postgis-users] postgis installation on current Postgresql (8.1) database (on Debian)
Assad Jarrahian
jarraa at gmail.com
Thu Jan 12 08:30:43 PST 2006
I pasted the complete output below. Thanks for your help.
make -C lwgeom
make[1]: Entering directory `/packages/postgis-1.1.0/lwgeom'
cpp -P -traditional-cpp -DUSE_VERSION=81 lwpostgis.sql.in | sed -e
's:@MODULE_FILENAME@:\$libdir/liblwgeom.so.1.1:g;s:@POSTGIS_VERSION@:1.1
USE_GEOS=1 USE_PROJ=1
USE_STATS=1:g;s:@POSTGIS_SCRIPTS_VERSION@:1.1.0:g;s/@POSTGIS_BUILD_DATE@/2006-01-12
16:30:40/g' | grep -v '^#' > ../lwpostgis.sql
/usr/bin/perl ../utils/postgis_proc_upgrade.pl ../lwpostgis.sql >
../lwpostgis_upgrade.sql
gcc -DUSE_VERSION=81 -DPOSTGIS_LIB_VERSION='"1.1.0"'
-DPOSTGIS_VERSION='"1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"'
-DPOSTGIS_SCRIPTS_VERSION='"1.1.0"' -DPOSTGIS_BUILD_DATE='"2006-01-12
16:30:40"' -I/usr/local/include -DUSE_PROJ
-I/usr/include/postgresql/8.1/server -DAUTOCACHE_BBOX=1 -DUSE_STATS
-Wall -g -O2 -fPIC -fexceptions -DUSE_GEOS -I/usr/local/include -c
-o measures.o measures.c
-o box2d.o box2d.c
-o ptarray.o ptarray.c
ptarray.c: In function 'ptarray_segmentize2d':
ptarray.c:223: warning: dereferencing type-punned pointer will break
strict-aliasing rules
-o lwgeom_api.o lwgeom_api.c
lwgeom_api.c: In function 'lwgeom_getpoint_inspected':
lwgeom_api.c:974: warning: pointer targets in assignment differ in signedness
lwgeom_api.c:981: warning: pointer targets in passing argument 1 of
'lwpoint_deserialize' differ in signedness
lwgeom_api.c: In function 'lwgeom_getpoly':
lwgeom_api.c:1051: warning: pointer targets in assignment differ in signedness
lwgeom_api.c:1057: warning: pointer targets in passing argument 1 of
'lwpoly_deserialize' differ in signedness
lwgeom_api.c: In function 'lwgeom_getpoly_inspected':
lwgeom_api.c:1069: warning: pointer targets in assignment differ in signedness
lwgeom_api.c:1076: warning: pointer targets in passing argument 1 of
lwgeom_api.c: In function 'lwgeom_getsubgeometry':
lwgeom_api.c:1097: warning: pointer targets in assignment differ in signedness
lwgeom_api.c:1099: warning: pointer targets in return differ in signedness
lwgeom_api.c: In function 'printPA':
lwgeom_api.c:1636: warning: pointer targets in assignment differ in signedness
lwgeom_api.c:1637: warning: pointer targets in assignment differ in signedness
lwgeom_api.c: In function 'printBYTES':
lwgeom_api.c:1674: warning: pointer targets in passing argument 2 of
'deparse_hex' differ in signedness
lwgeom_api.c: In function 'pglwgeom_from_ewkb':
lwgeom_api.c:1775: warning: pointer targets in passing argument 2 of
lwgeom_api.c: In function 'lwgeom_typeflags':
lwgeom_api.c:2000: warning: pointer targets in return differ in signedness
lwgeom_api.c: In function 'parse_lwgeom_wkt':
lwgeom_api.c:2242: warning: pointer targets in passing argument 1 of
'parse_lwg' differ in signedness
lwgeom_api.c: In function 'box2df_to_box3d':
lwgeom_api.c:220: warning: 'result.zmin' is used uninitialized in this function
lwgeom_api.c:220: warning: 'result.zmax' is used uninitialized in this function
lwgeom_api.c:220: warning: 'result.ymax' is used uninitialized in this function
lwgeom_api.c:220: warning: 'result.xmax' is used uninitialized in this function
lwgeom_api.c:220: warning: 'result.ymin' is used uninitialized in this function
lwgeom_api.c:220: warning: 'result.xmin' is used uninitialized in this function
-o lwgeom.o lwgeom.c
lwgeom.c: In function 'lwgeom_to_ewkb':
lwgeom.c:409: warning: pointer targets in return differ in signedness
-o lwpoint.o lwpoint.c
-o lwline.o lwline.c
-o lwpoly.o lwpoly.c
lwpoly.c: In function 'lwpoly_deserialize':
lwpoly.c:80: warning: pointer targets in assignment differ in signedness
lwpoly.c:90: warning: pointer targets in assignment differ in signedness
lwpoly.c:105: warning: pointer targets in passing argument 1 of
'get_int32' differ in signedness
lwpoly.c:113: warning: pointer targets in passing argument 1 of
'get_uint32' differ in signedness
lwpoly.c:121: warning: pointer targets in passing argument 1 of
lwpoly.c:124: warning: pointer targets in passing argument 1 of
'pointArray_construct' differ in signedness
-o lwmpoint.o lwmpoint.c
-o lwmline.o lwmline.c
-o lwmpoly.o lwmpoly.c
-o lwcollection.o lwcollection.c
-o wktunparse.o wktunparse.c
-o lwgparse.o lwgparse.c
-o wktparse.tab.o wktparse.tab.c
wktparse.y: In function 'lwg_parse_yyparse':
wktparse.y:43: warning: pointer targets in passing argument 1 of
'alloc_wkb' differ in signedness
-o lex.yy.o lex.yy.c
lex.yy.c:3044: warning: 'yyunput' defined but not used
-o vsprintf.o vsprintf.c
-o liblwgeom.o liblwgeom.c
In file included from liblwgeom.c:26:
lwgeom_pg.h:4:22: error: postgres.h: No such file or directory
lwgeom_pg.h:5:29: error: utils/geo_decls.h: No such file or directory
lwgeom_pg.h:6:18: error: fmgr.h: No such file or directory
lwgeom_pg.h:28: error: syntax error before 'getGeometryOID'
lwgeom_pg.h:28: warning: type defaults to 'int' in declaration of
'getGeometryOID'
lwgeom_pg.h:28: warning: data definition has no type or storage class
lwgeom_pg.h:35: error: syntax error before '*' token
lwgeom_pg.h:36: error: syntax error before 'box2df_to_box'
lwgeom_pg.h:36: warning: type defaults to 'int' in declaration of
'box2df_to_box'
lwgeom_pg.h:36: warning: data definition has no type or storage class
lwgeom_pg.h:37: error: syntax error before 'BOX'
lwgeom_pg.h:40: error: syntax error before 'BOX2D_same'
lwgeom_pg.h:40: warning: type defaults to 'int' in declaration of 'BOX2D_same'
lwgeom_pg.h:40: warning: parameter names (without types) in function declaration
lwgeom_pg.h:40: warning: data definition has no type or storage class
lwgeom_pg.h:41: error: syntax error before 'BOX2D_overlap'
lwgeom_pg.h:41: warning: type defaults to 'int' in declaration of
'BOX2D_overlap'
lwgeom_pg.h:41: warning: parameter names (without types) in function declaration
lwgeom_pg.h:41: warning: data definition has no type or storage class
lwgeom_pg.h:42: error: syntax error before 'BOX2D_overleft'
lwgeom_pg.h:42: warning: type defaults to 'int' in declaration of
'BOX2D_overleft'
lwgeom_pg.h:42: warning: parameter names (without types) in function declaration
lwgeom_pg.h:42: warning: data definition has no type or storage class
lwgeom_pg.h:43: error: syntax error before 'BOX2D_left'
lwgeom_pg.h:43: warning: type defaults to 'int' in declaration of 'BOX2D_left'
lwgeom_pg.h:43: warning: parameter names (without types) in function declaration
lwgeom_pg.h:43: warning: data definition has no type or storage class
lwgeom_pg.h:44: warning: type defaults to 'int' in declaration of 'BOX2D_right'
lwgeom_pg.h:44: warning: parameter names (without types) in function declaration
lwgeom_pg.h:44: warning: data definition has no type or storage class
lwgeom_pg.h:45: error: syntax error before 'BOX2D_overright'
lwgeom_pg.h:45: warning: type defaults to 'int' in declaration of
'BOX2D_overright'
lwgeom_pg.h:45: warning: parameter names (without types) in function declaration
lwgeom_pg.h:45: warning: data definition has no type or storage class
lwgeom_pg.h:46: error: syntax error before 'BOX2D_overbelow'
lwgeom_pg.h:46: warning: type defaults to 'int' in declaration of
'BOX2D_overbelow'
lwgeom_pg.h:46: warning: parameter names (without types) in function declaration
lwgeom_pg.h:46: warning: data definition has no type or storage class
lwgeom_pg.h:47: error: syntax error before 'BOX2D_below'
lwgeom_pg.h:47: warning: type defaults to 'int' in declaration of 'BOX2D_below'
lwgeom_pg.h:47: warning: parameter names (without types) in function declaration
lwgeom_pg.h:47: warning: data definition has no type or storage class
lwgeom_pg.h:48: error: syntax error before 'BOX2D_above'
lwgeom_pg.h:48: warning: type defaults to 'int' in declaration of 'BOX2D_above'
lwgeom_pg.h:48: warning: parameter names (without types) in function declaration
lwgeom_pg.h:48: warning: data definition has no type or storage class
lwgeom_pg.h:49: error: syntax error before 'BOX2D_overabove'
lwgeom_pg.h:49: warning: type defaults to 'int' in declaration of
'BOX2D_overabove'
lwgeom_pg.h:49: warning: parameter names (without types) in function declaration
lwgeom_pg.h:49: warning: data definition has no type or storage class
lwgeom_pg.h:50: error: syntax error before 'BOX2D_contained'
lwgeom_pg.h:50: warning: type defaults to 'int' in declaration of
'BOX2D_contained'
lwgeom_pg.h:50: warning: parameter names (without types) in function declaration
lwgeom_pg.h:50: warning: data definition has no type or storage class
lwgeom_pg.h:51: error: syntax error before 'BOX2D_contain'
lwgeom_pg.h:51: warning: type defaults to 'int' in declaration of
'BOX2D_contain'
lwgeom_pg.h:51: warning: parameter names (without types) in function declaration
lwgeom_pg.h:51: warning: data definition has no type or storage class
lwgeom_pg.h:52: error: syntax error before 'BOX2D_intersects'
lwgeom_pg.h:52: warning: type defaults to 'int' in declaration of
'BOX2D_intersects'
lwgeom_pg.h:52: warning: parameter names (without types) in function declaration
lwgeom_pg.h:52: warning: data definition has no type or storage class
lwgeom_pg.h:53: error: syntax error before 'BOX2D_union'
lwgeom_pg.h:53: warning: type defaults to 'int' in declaration of 'BOX2D_union'
lwgeom_pg.h:53: warning: parameter names (without types) in function declaration
lwgeom_pg.h:53: warning: data definition has no type or storage class
lwgeom_pg.h:55: error: syntax error before 'LWGEOM_same'
lwgeom_pg.h:55: warning: type defaults to 'int' in declaration of 'LWGEOM_same'
lwgeom_pg.h:55: warning: parameter names (without types) in function declaration
lwgeom_pg.h:55: warning: data definition has no type or storage class
lwgeom_pg.h:56: error: syntax error before 'BOX3D_construct'
lwgeom_pg.h:56: warning: type defaults to 'int' in declaration of
'BOX3D_construct'
lwgeom_pg.h:56: warning: parameter names (without types) in function declaration
lwgeom_pg.h:56: warning: data definition has no type or storage class
lwgeom_pg.h:57: error: syntax error before 'BOX2DFLOAT4_ymin'
lwgeom_pg.h:57: warning: type defaults to 'int' in declaration of
'BOX2DFLOAT4_ymin'
lwgeom_pg.h:57: warning: parameter names (without types) in function declaration
lwgeom_pg.h:57: warning: data definition has no type or storage class
lwgeom_pg.h:59: error: syntax error before 'LWGEOM_force_2d'
lwgeom_pg.h:59: warning: type defaults to 'int' in declaration of
'LWGEOM_force_2d'
lwgeom_pg.h:59: warning: parameter names (without types) in function declaration
lwgeom_pg.h:59: warning: data definition has no type or storage class
lwgeom_pg.h:60: error: syntax error before 'LWGEOM_force_3dm'
lwgeom_pg.h:60: warning: type defaults to 'int' in declaration of
'LWGEOM_force_3dm'
lwgeom_pg.h:60: warning: parameter names (without types) in function declaration
lwgeom_pg.h:60: warning: data definition has no type or storage class
lwgeom_pg.h:61: error: syntax error before 'LWGEOM_force_3dz'
lwgeom_pg.h:61: warning: type defaults to 'int' in declaration of
'LWGEOM_force_3dz'
lwgeom_pg.h:61: warning: parameter names (without types) in function declaration
lwgeom_pg.h:61: warning: data definition has no type or storage class
lwgeom_pg.h:62: error: syntax error before 'LWGEOM_force_4d'
lwgeom_pg.h:62: warning: data definition has no type or storage class
lwgeom_pg.h:63: error: syntax error before 'LWGEOM_force_collection'
lwgeom_pg.h:63: warning: type defaults to 'int' in declaration of
lwgeom_pg.h:63: warning: parameter names (without types) in function declaration
lwgeom_pg.h:63: warning: data definition has no type or storage class
lwgeom_pg.h:64: error: syntax error before 'LWGEOM_force_multi'
lwgeom_pg.h:64: warning: type defaults to 'int' in declaration of
lwgeom_pg.h:64: warning: parameter names (without types) in function declaration
lwgeom_pg.h:64: warning: data definition has no type or storage class
lwgeom_pg.h:66: error: syntax error before 'LWGEOMFromWKB'
lwgeom_pg.h:66: warning: type defaults to 'int' in declaration of
'LWGEOMFromWKB'
lwgeom_pg.h:66: warning: parameter names (without types) in function declaration
lwgeom_pg.h:66: warning: data definition has no type or storage class
lwgeom_pg.h:67: error: syntax error before 'WKBFromLWGEOM'
lwgeom_pg.h:67: warning: type defaults to 'int' in declaration of
'WKBFromLWGEOM'
lwgeom_pg.h:67: warning: parameter names (without types) in function declaration
lwgeom_pg.h:67: warning: data definition has no type or storage class
lwgeom_pg.h:69: error: syntax error before 'LWGEOM_getBBOX'
lwgeom_pg.h:69: warning: type defaults to 'int' in declaration of
'LWGEOM_getBBOX'
lwgeom_pg.h:69: warning: parameter names (without types) in function declaration
lwgeom_pg.h:69: warning: data definition has no type or storage class
lwgeom_pg.h:70: error: syntax error before 'LWGEOM_addBBOX'
lwgeom_pg.h:70: warning: type defaults to 'int' in declaration of
'LWGEOM_addBBOX'
lwgeom_pg.h:70: warning: parameter names (without types) in function declaration
lwgeom_pg.h:70: warning: data definition has no type or storage class
lwgeom_pg.h:71: error: syntax error before 'LWGEOM_dropBBOX'
lwgeom_pg.h:71: warning: type defaults to 'int' in declaration of
'LWGEOM_dropBBOX'
lwgeom_pg.h:71: warning: parameter names (without types) in function declaration
lwgeom_pg.h:71: warning: data definition has no type or storage class
liblwgeom.c: In function 'trim_trailing_zeros':
liblwgeom.c:158: warning: implicit declaration of function 'strchr'
liblwgeom.c:158: warning: incompatible implicit declaration of
built-in function 'strchr'
liblwgeom.c:163: warning: implicit declaration of function 'strlen'
liblwgeom.c:163: warning: incompatible implicit declaration of
built-in function 'strlen'
make[1]: *** [liblwgeom.o] Error 1
On 1/12/06, strk at refractions.net <strk at refractions.net> wrote:
> Please show some more lines - starting right before the *first*
> warning during make - after a make clean.
> --strk;
> On Thu, Jan 12, 2006 at 08:39:25AM -0700, Assad Jarrahian wrote:
> > I am talking about the latest release 1.10
> > Yes it seems that I can find postgres.h
> > pg_config --includedir-server
> > What should I do with it?
> > thanks.
> > -assad
> > > You're talking about postgis version ?
> > > Can you find postgres.h under `/usr/bin/pg_config --includedir-server` ?
> > > --strk;
> > > On Thu, Jan 12, 2006 at 01:46:17AM -0700, Assad Jarrahian wrote:
> > > > David and all,
> > > > Thanks. I got everything installed, but when installing postgis I
> > > > got errors (see below).
> > > > The configure summary:
> > > > SUMMARY
> > > > HOST_OS: linux-gnu
> > > > PGSQL: /usr/bin/pg_config
> > > > GEOS: /usr/local/bin/geos-config (with C-API)
> > > > PROJ: dir=/usr/local
> > > > ICONV: 1
> > > > PORTNAME: linux
> > > > PREFIX: /usr
> > > > EPREFIX: ${prefix}
> > > > DOC: /usr/share/doc/postgresql-doc-8.1
> > > > DATA: /usr/share/postgresql/8.1/postgresql/contrib
> > > > MAN: /usr/share/postgresql/8.1/man
> > > > BIN: /usr/lib/postgresql/8.1/bin
> > > > EXT: /usr/lib/postgresql/8.1/lib (\$$libdir)
> > > > and the errors:
> > > > 'getGeometryOID'
> > > > 'box2df_to_box'
> > > > 'BOX2D_overlap'
> > > > 'BOX2D_overleft'
> > > > lwgeom_pg.h:44: error: syntax error before 'BOX2D_right'
> > > > 'BOX2D_overright'
> > > > 'BOX2D_overbelow'
> > > > 'BOX2D_overabove'
> > > > 'BOX2D_contained'
> > > > 'BOX2D_contain'
> > > > 'LWGEOM_getBBOX'
> > > > 'LWGEOM_addBBOX'
> > > > 'LWGEOM_dropBBOX'
> > > > make: *** [liblwgeom] Error 2
> > > > On 1/12/06, Stefano Costa <steko at iosa.it> wrote:
> > > > > Il giorno gio, 12/01/2006 alle 00.28 -0700, Assad Jarrahian ha scritto:
> > > > > > hey david and all,
> > > > > > thanks for replying.
> > > > > > I tried the first step and it raised an exception
> > > > > > sudo apt-get postgresql-dev
> > > > > > E: Invalid operation postgresql-dev
> > > > > You should add an "install" just like this:
> > > > > sudo apt-get install postgresql-dev
> > > > > Regards,
> > > > > Stefano
> > > > > Stefano Costa
> > > > > http://www.iosa.it Software Open Source per l'Archeologia
> > > > > Jabber: steko at jabber.linux.it
> > > > > GnuPG Key ID 1024D/0xD0D30245
> > > > > Linux Registered User #385969 counter.li.org
> > > > > _______________________________________________
> > > > > postgis-users mailing list
> > > > > postgis-users at postgis.refractions.net
> > > > > http://postgis.refractions.net/mailman/listinfo/postgis-users
> > > /"\ ASCII Ribbon Campaign
> > > \ / Respect for low technology.
> > > X Keep e-mail messages readable by any computer system.
> > > / \ Keep it ASCII.
> / \ Keep it ASCII.
