[postgis-users] postgis_restore.pl loads no data (pg-8.1, postgis-1.1)
Benjamin Thelen bt at ccgis.de
Fri Jan 13 07:45:13 PST 2006
I ran the following tests:
Two different dumps made with "pg_dump -O -Fc" from two FreeBSD-6 boxes
running postgresql-8.0.4/postgis-1.0.4.
I have three FreeBSD 6 boxes running postgresql-8.1.2/postgis-1.1.0 and
one Ubuntu box running postgresql-8.0.4/postgis-1.1.0.
All dumps stopped at the same stage as shown in my first mail:
-- END
COMMIT;
COMMIT
DROP TABLE geometry_columns;DROP TABLE spatial_ref_sys;
DROP TABLE
DROP TABLE
PostGIS functions are uploaded, but no data. The prompt is not shown,
what indicates that something is waiting, not doing the exepected or
whatever (Ctrl+C is required).
The most interesting part for me is that as I downgraded postgis-1.1.0
to postgis-1.0.6 on a FreeBSD box running postgresql-8.1.2 I succeeded
uploading the dump!
I also made a regression test on this machine, showing a successfull run:
$ gmake test
gmake -C regress test
gmake[1]: Entering directory `/usr/data/tmp/postgis-1.1.0/regress'
Creating spatial db postgis_reg
  PostgreSQL 8.1.2 on i386-portbld-freebsd6.0, compiled by GCC cc (GCC)
3.4.4 [FreeBSD] 20050518
  Postgis 1.1.0 - 2006-01-13 11:55:43
    GEOS: 2.2.1-CAPI-1.0.1
    PROJ: Rel. 4.4.9, 29 Oct 2004
Running tests
            regress: Ok.
      regress_index: Ok.
     lwgeom_regress: Ok.
        regress_lrs: Ok.
        removepoint: Ok.
           setpoint: Ok.
        regress_ogc: Ok.
     regress_bdpoly: Ok.
       regress_proj: Ok.
Run tests: 9
Successful: 9
Failed: 0
gmake[1]: Leaving directory `/usr/data/tmp/postgis-1.1.0/regress'
Any idea?
Thanks,
Ben
strk at refractions.net schrieb:
> Please give postgis_restore.pl a try and let use know.
> --strk;
> On Thu, Jan 12, 2006 at 07:50:19PM +0100, Benjamin Thelen wrote:
>> Hi list,
>> I backed up a postgresql/postgis DB from a
>> postgresql-8.0.4/postgis-1.0.4 combination and tried to restore the dump
>> into a 8.1.2/1.1.0 combination and failed. It seems that all
>> (functions,..) but the data itself is uploaded. The procedure just stops
>> as it seems without any error message. Please have a look at the end of
>> the output below.
>> The most interesting part is that I also tried to upload the same dump
>> into the same DB but using an old postgis_restore.pl from postgis-1.0.4
>> and succeeded! At least it seems at first glance. In this case the
>> output doesn't stop as you see below, but continues to load the data
>> itself into the database.
>> I couldn't find anything on the internet, just the information, that
>> postgis itself is pg-8.1 compatible and postgis_restore.pl hasn't
>> officially been testet with this pg version.
>> I'm a bit at a loss. Do I have to go back to 8.0? Is there something
>> I've overlooked, I can do?
>> Thanks,
>> Ben
>> LANGUAGE 'plpgsql' IMMUTABLE STRICT;
>> CREATE FUNCTION
>> -- SFSQL 1.1
>> -- BdMPolyFromText(multiLineStringTaggedText String, SRID Integer):
>> MultiPolygon
>> --  Construct a MultiPolygon given an arbitrary
>> --  collection of closed linestrings as a
>> --  MultiLineString text representation.
>> -- This is a PLPGSQL function rather then an SQL function
>> -- To raise an exception in case of invalid input.
>> CREATE OR REPLACE FUNCTION BdMPolyFromText(text, integer)
>> RETURNS geometry
>> AS '
>> DECLARE
>> 	geomtext alias for $1;
>> 	srid alias for $2;
>> 	mline geometry;
>> 	geom geometry;
>> BEGIN
>> 	mline := MultiLineStringFromText(geomtext, srid);
>> 	IF mline IS NULL
>> 	THEN
>> 		RAISE EXCEPTION ''Input is not a MultiLinestring'';
>> 	END IF;
>> 	geom := multi(BuildArea(mline));
>> 	RETURN geom;
>> END;
>> CREATE FUNCTION
>> -- END
>> COMMIT;
>> COMMIT
>> DROP TABLE
>> DROP TABLE
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
