[postgis-users] postgis_restore.pl loads no data (pg-8.1, postgis-1.1)
Benjamin Thelen bt at ccgis.de
Mon Jan 16 04:29:56 PST 2006
Another attempt:
My FreeBSD 6 box at home, installed a postgres-8.1.2, postgis-1.1.0,
converted some shape data with shp2pgsql and made a backup with pg_dump
-FC. I again could not successfully upload the backup with
postigs_restore.pl.
Again, using postgis_restore.pl from postgis 1.0.6 or downgrading, leads
to a successful upload.
No more ideas.
Best,
Ben
strk at refractions.net schrieb:
> Please give postgis_restore.pl a try and let use know.
> --strk;
> On Thu, Jan 12, 2006 at 07:50:19PM +0100, Benjamin Thelen wrote:
>> Hi list,
>> I backed up a postgresql/postgis DB from a
>> postgresql-8.0.4/postgis-1.0.4 combination and tried to restore the dump
>> into a 8.1.2/1.1.0 combination and failed. It seems that all
>> (functions,..) but the data itself is uploaded. The procedure just stops
>> as it seems without any error message. Please have a look at the end of
>> the output below.
>> The most interesting part is that I also tried to upload the same dump
>> into the same DB but using an old postgis_restore.pl from postgis-1.0.4
>> and succeeded! At least it seems at first glance. In this case the
>> output doesn't stop as you see below, but continues to load the data
>> itself into the database.
>> I couldn't find anything on the internet, just the information, that
>> postgis itself is pg-8.1 compatible and postgis_restore.pl hasn't
>> officially been testet with this pg version.
>> I'm a bit at a loss. Do I have to go back to 8.0? Is there something
>> I've overlooked, I can do?
>> Thanks,
>> Ben
>> LANGUAGE 'plpgsql' IMMUTABLE STRICT;
>> CREATE FUNCTION
>> -- SFSQL 1.1
>> -- BdMPolyFromText(multiLineStringTaggedText String, SRID Integer):
>> MultiPolygon
>> --  Construct a MultiPolygon given an arbitrary
>> --  collection of closed linestrings as a
>> --  MultiLineString text representation.
>> -- This is a PLPGSQL function rather then an SQL function
>> -- To raise an exception in case of invalid input.
>> CREATE OR REPLACE FUNCTION BdMPolyFromText(text, integer)
>> RETURNS geometry
>> AS '
>> DECLARE
>> 	geomtext alias for $1;
>> 	srid alias for $2;
>> 	mline geometry;
>> 	geom geometry;
>> BEGIN
>> 	mline := MultiLineStringFromText(geomtext, srid);
>> 	IF mline IS NULL
>> 	THEN
>> 		RAISE EXCEPTION ''Input is not a MultiLinestring'';
>> 	END IF;
>> 	geom := multi(BuildArea(mline));
>> 	RETURN geom;
>> END;
>> CREATE FUNCTION
>> -- END
>> COMMIT;
>> COMMIT
>> DROP TABLE geometry_columns;DROP TABLE spatial_ref_sys;
>> DROP TABLE
>> DROP TABLE
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
