[postgis-users] postgis_restore.pl loads no data (pg-8.1, postgis-1.1)
strk at refractions.net
Mon Jan 16 04:32:38 PST 2006
Still hung? What is your computed doing during the hung ?
Can you show initial lines of top(1) output ?
Can you show output/error of postgis_restore.pl run ?
--strk;
On Mon, Jan 16, 2006 at 01:29:56PM +0100, Benjamin Thelen wrote:
> Another attempt:
> My FreeBSD 6 box at home, installed a postgres-8.1.2, postgis-1.1.0,
> converted some shape data with shp2pgsql and made a backup with pg_dump
> -FC. I again could not successfully upload the backup with
> postigs_restore.pl.
> Again, using postgis_restore.pl from postgis 1.0.6 or downgrading, leads
> to a successful upload.
> No more ideas.
> Best,
> Ben
> strk at refractions.net schrieb:
> >Please give postgis_restore.pl a try and let use know.
> >--strk;
> >On Thu, Jan 12, 2006 at 07:50:19PM +0100, Benjamin Thelen wrote:
> >>Hi list,
> >>I backed up a postgresql/postgis DB from a
> >>postgresql-8.0.4/postgis-1.0.4 combination and tried to restore the dump
> >>into a 8.1.2/1.1.0 combination and failed. It seems that all
> >>(functions,..) but the data itself is uploaded. The procedure just stops
> >>as it seems without any error message. Please have a look at the end of
> >>the output below.
> >>The most interesting part is that I also tried to upload the same dump
> >>into the same DB but using an old postgis_restore.pl from postgis-1.0.4
> >>and succeeded! At least it seems at first glance. In this case the
> >>output doesn't stop as you see below, but continues to load the data
> >>itself into the database.
> >>I couldn't find anything on the internet, just the information, that
> >>postgis itself is pg-8.1 compatible and postgis_restore.pl hasn't
> >>officially been testet with this pg version.
> >>I'm a bit at a loss. Do I have to go back to 8.0? Is there something
> >>I've overlooked, I can do?
> >>Thanks,
> >>Ben
> >>LANGUAGE 'plpgsql' IMMUTABLE STRICT;
> >>CREATE FUNCTION
> >>-- SFSQL 1.1
> >>-- BdMPolyFromText(multiLineStringTaggedText String, SRID Integer):
> >>MultiPolygon
> >>-- Construct a MultiPolygon given an arbitrary
> >>-- collection of closed linestrings as a
> >>-- MultiLineString text representation.
> >>-- This is a PLPGSQL function rather then an SQL function
> >>-- To raise an exception in case of invalid input.
> >>CREATE OR REPLACE FUNCTION BdMPolyFromText(text, integer)
> >>RETURNS geometry
> >>AS '
> >>DECLARE
> >> geomtext alias for $1;
> >> srid alias for $2;
> >> mline geometry;
> >> geom geometry;
> >>BEGIN
> >> mline := MultiLineStringFromText(geomtext, srid);
> >> IF mline IS NULL
> >> THEN
> >> RAISE EXCEPTION ''Input is not a MultiLinestring'';
> >> END IF;
> >> geom := multi(BuildArea(mline));
> >> RETURN geom;
> >>END;
> >>CREATE FUNCTION
> >>-- END
> >>COMMIT;
> >>COMMIT
> >>DROP TABLE geometry_columns;DROP TABLE spatial_ref_sys;
> >>DROP TABLE
> >>DROP TABLE
> >>_______________________________________________
> >>postgis-users mailing list
> >>postgis-users at postgis.refractions.net
> >>http://postgis.refractions.net/mailman/listinfo/postgis-users
/"\ ASCII Ribbon Campaign
\ / Respect for low technology.
X Keep e-mail messages readable by any computer system.
/ \ Keep it ASCII.
