[postgis-users] distance_sphere() with polygons
Daniel Ricard
ricardd at mathstat.dal.ca
Fri Jan 13 07:48:59 PST 2006
Hello all,
Is there a trick to using distance_sphere() or distance_spheroid() when one
wants the distance between a point and the boundary of a polygon?
I've been using:
SELECT distance(i.the_geom, boundary(j.the_geom))
and would now like to obtain distance in meters instead of degrees.
The documentation say that distance_sphere() and others only work for points
but there must be a way to do this. Help greatly appreciated.
Cheers,
Dan
