[postgis-users] (no subject)
TECHER David davidtecher at yahoo.fr
Fri Jan 13 13:43:26 PST 2006
Hi Peter
When PostGIS Regression Tests if it complains about geos
error about  libgeos (if you've installed geos 2.2.1) it is because
/usr/local/lib where U can find it in geos lib is not in your
LD_LIBRARY_PATH
so as root
do
echo $(geos-config --prefix)/lib >> /etc/ld.so.conf
ldconfig -v | grep libgeos
that should give you something like
libgeos.so.2 -> libgeos.so.2.1.3
or
libgeos.so.2 -> libgeos.so.2.2.1
then
psql -U postgres -d template1 -c "drop database postgis_reg"
rerun postgis regression test
Peter König a écrit :
>Hi all,
>I am trying to install PostGIS on an Ubuntu-Linux for two days now -
>unfortunatly without success. Since I saw some postings here about
>successful installations on Ubuntu and the AMD64-architecture, maybe there
>is someone who could give me a hint.
>The first attemt was to install Postgres via the source-distribution:
>apt-get -b source postgresql-8.0 postgresql-server-dev-8.0
>I also installed proj and geos.
>Then I copied PostGIS-archive (tried 1.1 and 1.06) to the pg-contrib-dir
>in the "build-tree"-path and extracted them there. After configuring
>(1.1)/ modifiying the Makefile.config (1.0.6), proj and geos were
>correctly found, "make" and "make install" proceeded without errors (but
>many warnings [*] ) and I got liblwgeom.so.xx in
>/usr/lib/postgresql/8.0/lib (liblwgeom.so.1 and liblwgeom.so in the same
>dir were link to it)
>Then I chowned the regess-dir to postgres:postgres and started "make" in
>that dir (as user "postgres") to perform the tests. V 1.0.6 produced a lot
>of errors complaining about an uninstalled "geos" and with V 1.1.0 I
>received the message, that 8 of 9 tests have failed. Although I see the
>PostGIS-Funtions in a new db they do not work.
>Another approach was to try to install the ubuntu deb-package of postgis
>1.0.6 from arocaware, but it also failed.
>Any idea to solve this would be welcome. Thanks,
>Peter
>Warnung: Zeigerziele in Zuweisung unterscheiden sich im Vorzeichenbesitz
>Warnung: Zeigerziele bei Übergabe des Arguments 1 von »HexDecode«
>May be loosly translated as "the targets of the pointers in the assignment
>are differently signed" and "the targets of the pointers of argument 1 of
>HexDecode are differently signed" (I am not c-coder ..).
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
___________________________________________________________________________
Nouveau : téléphonez moins cher avec Yahoo! Messenger ! Découvez les tarifs exceptionnels pour appeler la France et l'international.
Téléchargez sur http://fr.messenger.yahoo.com
