[postgis-users] postgis installation on current Postgresql (8.1) database (on Debian)
Stephen Woodbridge woodbri at swoodbridge.com
Sun Jan 15 21:02:55 PST 2006
Hi Alex,
I'm running Debian Sarge on amd64 box with 2.6.15-1-em64t-p4-smp #1 SMP.
OK, here is what I did:
cd /usr/src
# downloaded postgis-1.1.0.tar.gz from the postgis site
tar xzf postgis-1.1.0.tar.gz
cd postgis-1.1.0
zcat ../postgis_1.1.0-2.diff.gz | patch -p1
chmod ug+x debian/rules
dpkg-buildpackage -rfakeroot
and this failed with unmet dependencices
debian/control has:
Build-Depends: debhelper (>= 4.0.0), devscripts, gawk | awk, binutils |
binutils-multiarch, flex, bison, autoconf, proj, libpgjava, gcj |
java-compiler, fastjar , postgresql-server-dev-8.0,
postgresql-server-dev-7.4, postgresql-server-dev-8.1
changed to:
java-compiler, fastjar , postgresql-server-dev-8.0 |
postgresql-server-dev-7.4 | postgresql-server-dev-8.1
But this file seems to be auto-generated from:
debian/control.source/control.0
java-compiler, fastjar, postgresql-server-dev-7.4 | postgresql-dev (>=
7.2.0), postgresql-server-dev-8.0 | postgresql-dev (>= 7.2.0),
postgresql-server-dev-8.1 | postgresql-dev (>= 7.2.0)
which I changed to:
7.2.0) | postgresql-server-dev-8.0 | postgresql-dev (>= 7.2.0) |
Notice all the *dev* after fastjar are now separated by '|' insteaqd of
commas.
-Steve
alex bodnaru wrote:
> hi steve,
> happy to hear you are using my software.
> would you please be more specific on the fixes you needed? (i might do
> it for all).
> please be also specific on the debian version you use.
> alex
> On Sun, 2006-01-15 at 21:58 -0500, Stephen Woodbridge wrote:
>>Hi Alex,
>>Your patch and process works, but has a minor bug in it. You need to fix
>>the package dependencies. You have listed all the *-dev packages
>>separated with commas ',' instead of pipes '|' once I fixed that is
>>compiled and installed fine on Debian sarge amd64 platform.
>>-Steve
>>>Hi Alex,
>>>I am running a debian sarge amd64 system and have grabbed the sid source
>>>for postgresql and build it. Is there a package for postGIS-1.1.0 that I
>>>can download and build for dpkg?
>>>It looks like I might be able to follow the pocedure your listed below.
>>>Is this correct? I have the patch file you posted before.
>>>Thanks,
>>>  -Steve
>>>alex bodnaru wrote:
>>>>assad,
>>>>your ./configure output seems a little wird for a clean postgresql sarge
>>>>installation.
>>>>the procedure below will possibly help. if still in problem, you might
>>>>need to have a better backported postgresql for sarge, or upgrade debian.
>>>>please apply this diff to the *clean* postgis source:
>>>>cd postgis_source_root
>>>>zcat the_attached_file | patch -p1
>>>># you should have ./debian subdirectory in postgis_source_root
>>>>good luck,
>>>>alex
>>>>Assad Jarrahian wrote:
>>>>>Alex,
>>>>> I am running sarge. How do I get a hold of that package.
>>>>>I looked at
>>>>>http://pkg-grass.alioth.debian.org/cgi-bin/wiki.pl/PackageList
>>>>>and it says postgis (now uninstallable)
>>>>>thanks for your help alex.
>>>>>-assad
>>>>>On 1/13/06, alex bodnaru <alexbodn at 012.net.il> wrote:
>>>>>>what debian version do you have?
>>>>>>>I took a closer look. The directory /usr/include/postgresql/ exists
>>>>>>>and postgres.h is in that directory.
>>>>>>>There is no 8.1 directory.
>>>>>>>How do I mend the problem (tell pg-config that the directory is
>>>>>>>somewhere else)
>>>>>>>much thanks and sorry for the initial lookover of the file existing.
>>>>>>>-assad
>>>>>>>On 1/13/06, strk at refractions.net <strk at refractions.net> wrote:
>>>>>>>>This is your problem:
>>>>>>>>gcc -DUSE_VERSION=81 -DPOSTGIS_LIB_VERSION='"1.1.0"'
>>>>>>>>-DPOSTGIS_VERSION='"1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"'
>>>>>>>>-DPOSTGIS_SCRIPTS_VERSION='"1.1.0"' -DPOSTGIS_BUILD_DATE='"2006-01-12
>>>>>>>>16:30:40"' -I/usr/local/include -DUSE_PROJ
>>>>>>>>-I/usr/include/postgresql/8.1/server -DAUTOCACHE_BBOX=1  -DUSE_STATS
>>>>>>>>-Wall -g -O2 -fPIC -fexceptions -DUSE_GEOS
>>>>>>>>-I/usr/local/include     -c
>>>>>>>>-o liblwgeom.o liblwgeom.c
>>>>>>>>In file included from liblwgeom.c:26:
>>>>>>>>lwgeom_pg.h:4:22: error: postgres.h: No such file or directory
>>>>>>>>Do you stil confirm that this file exist:
>>>>>>>>     /usr/include/postgresql/8.1/server/postgres.h
>>>>>>>>--strk;
>>>>>>>>On Fri, Jan 13, 2006 at 01:15:45AM -0700, Assad Jarrahian wrote:
>>>>>>>>>strk, stefano, david .... please help. Am stuck.
>>>>>>>>>Thanks.
>>>>>>>>>-assad
>>>>>>>>>On 1/12/06, Assad Jarrahian <jarraa at gmail.com> wrote:
>>>>>>>>>>I pasted the complete output below. Thanks for your help.
>>>>>>>>>>make -C lwgeom
>>>>>>>>>>make[1]: Entering directory `/packages/postgis-1.1.0/lwgeom'
>>>>>>>>>>cpp -P -traditional-cpp -DUSE_VERSION=81 lwpostgis.sql.in | sed -e
>>>>>>>>>>'s:@MODULE_FILENAME@:\$libdir/liblwgeom.so.1.1:g;s:@POSTGIS_VERSION@:1.1
>>>>>>>>>>USE_STATS=1:g;s:@POSTGIS_SCRIPTS_VERSION@:1.1.0:g;s/@POSTGIS_BUILD_DATE@/2006-01-12
>>>>>>>>>>16:30:40/g' | grep -v '^#' > ../lwpostgis.sql
>>>>>>>>>>/usr/bin/perl ../utils/postgis_proc_upgrade.pl ../lwpostgis.sql >
>>>>>>>>>>../lwpostgis_upgrade.sql
>>>>>>>>>>-DUSE_STATS
>>>>>>>>>>-o measures.o measures.c
>>>>>>>>>>-DUSE_STATS
>>>>>>>>>>-o box2d.o box2d.c
>>>>>>>>>>-DUSE_STATS
>>>>>>>>>>-o ptarray.o ptarray.c
>>>>>>>>>>ptarray.c: In function 'ptarray_segmentize2d':
>>>>>>>>>>ptarray.c:223: warning: dereferencing type-punned pointer will
>>>>>>>>>>break
>>>>>>>>>>strict-aliasing rules
>>>>>>>>>>break
>>>>>>>>>>-DUSE_STATS
>>>>>>>>>>-o lwgeom_api.o lwgeom_api.c
>>>>>>>>>>lwgeom_api.c: In function 'lwgeom_getpoint_inspected':
>>>>>>>>>>lwgeom_api.c:974: warning: pointer targets in assignment differ
>>>>>>>>>>in signedness
>>>>>>>>>>lwgeom_api.c:981: warning: pointer targets in passing argument 1 of
>>>>>>>>>>'lwpoint_deserialize' differ in signedness
>>>>>>>>>>lwgeom_api.c: In function 'lwgeom_getpoly':
>>>>>>>>>>lwgeom_api.c:1051: warning: pointer targets in assignment differ
>>>>>>>>>>in signedness
>>>>>>>>>>lwgeom_api.c:1057: warning: pointer targets in passing argument
>>>>>>>>>>1 of
>>>>>>>>>>'lwpoly_deserialize' differ in signedness
>>>>>>>>>>lwgeom_api.c: In function 'lwgeom_getpoly_inspected':
>>>>>>>>>>lwgeom_api.c:1069: warning: pointer targets in assignment differ
>>>>>>>>>>in signedness
>>>>>>>>>>lwgeom_api.c:1076: warning: pointer targets in passing argument
>>>>>>>>>>1 of
>>>>>>>>>>lwgeom_api.c: In function 'lwgeom_getsubgeometry':
>>>>>>>>>>lwgeom_api.c:1097: warning: pointer targets in assignment differ
>>>>>>>>>>in signedness
>>>>>>>>>>lwgeom_api.c:1099: warning: pointer targets in return differ in
>>>>>>>>>>signedness
>>>>>>>>>>lwgeom_api.c: In function 'printPA':
>>>>>>>>>>lwgeom_api.c:1636: warning: pointer targets in assignment differ
>>>>>>>>>>in signedness
>>>>>>>>>>lwgeom_api.c:1637: warning: pointer targets in assignment differ
>>>>>>>>>>in signedness
>>>>>>>>>>lwgeom_api.c: In function 'printBYTES':
>>>>>>>>>>lwgeom_api.c:1674: warning: pointer targets in passing argument
>>>>>>>>>>2 of
>>>>>>>>>>'deparse_hex' differ in signedness
>>>>>>>>>>lwgeom_api.c: In function 'pglwgeom_from_ewkb':
>>>>>>>>>>lwgeom_api.c:1775: warning: pointer targets in passing argument
>>>>>>>>>>2 of
>>>>>>>>>>lwgeom_api.c: In function 'lwgeom_typeflags':
>>>>>>>>>>lwgeom_api.c:2000: warning: pointer targets in return differ in
>>>>>>>>>>signedness
>>>>>>>>>>lwgeom_api.c: In function 'parse_lwgeom_wkt':
>>>>>>>>>>lwgeom_api.c:2242: warning: pointer targets in passing argument
>>>>>>>>>>1 of
>>>>>>>>>>'parse_lwg' differ in signedness
>>>>>>>>>>lwgeom_api.c: In function 'box2df_to_box3d':
>>>>>>>>>>lwgeom_api.c:220: warning: 'result.zmin' is used uninitialized
>>>>>>>>>>in this function
>>>>>>>>>>lwgeom_api.c:220: warning: 'result.zmax' is used uninitialized
>>>>>>>>>>in this function
>>>>>>>>>>lwgeom_api.c:220: warning: 'result.ymax' is used uninitialized
>>>>>>>>>>in this function
>>>>>>>>>>lwgeom_api.c:220: warning: 'result.xmax' is used uninitialized
>>>>>>>>>>in this function
>>>>>>>>>>lwgeom_api.c:220: warning: 'result.ymin' is used uninitialized
>>>>>>>>>>in this function
>>>>>>>>>>lwgeom_api.c:220: warning: 'result.xmin' is used uninitialized
>>>>>>>>>>in this function
>>>>>>>>>>-DUSE_STATS
>>>>>>>>>>-o lwgeom.o lwgeom.c
>>>>>>>>>>lwgeom.c: In function 'lwgeom_to_ewkb':
>>>>>>>>>>lwgeom.c:409: warning: pointer targets in return differ in
>>>>>>>>>>signedness
>>>>>>>>>>-DUSE_STATS
>>>>>>>>>>-o lwpoint.o lwpoint.c
>>>>>>>>>>-DUSE_STATS
>>>>>>>>>>-o lwline.o lwline.c
>>>>>>>>>>-DUSE_STATS
>>>>>>>>>>-o lwpoly.o lwpoly.c
>>>>>>>>>>lwpoly.c: In function 'lwpoly_deserialize':
>>>>>>>>>>lwpoly.c:80: warning: pointer targets in assignment differ in
>>>>>>>>>>signedness
>>>>>>>>>>lwpoly.c:90: warning: pointer targets in assignment differ in
>>>>>>>>>>signedness
>>>>>>>>>>lwpoly.c:105: warning: pointer targets in passing argument 1 of
>>>>>>>>>>'get_int32' differ in signedness
>>>>>>>>>>lwpoly.c:113: warning: pointer targets in passing argument 1 of
>>>>>>>>>>'get_uint32' differ in signedness
>>>>>>>>>>lwpoly.c:121: warning: pointer targets in passing argument 1 of
>>>>>>>>>>lwpoly.c:124: warning: pointer targets in passing argument 1 of
>>>>>>>>>>'pointArray_construct' differ in signedness
>>>>>>>>>>-DUSE_STATS
>>>>>>>>>>-o lwmpoint.o lwmpoint.c
>>>>>>>>>>-DUSE_STATS
>>>>>>>>>>-o lwmline.o lwmline.c
>>>>>>>>>>-DUSE_STATS
>>>>>>>>>>-o lwmpoly.o lwmpoly.c
>>>>>>>>>>-DUSE_STATS
>>>>>>>>>>-o lwcollection.o lwcollection.c
>>>>>>>>>>-DUSE_STATS
>>>>>>>>>>-o wktunparse.o wktunparse.c
>>>>>>>>>>-DUSE_STATS
>>>>>>>>>>-o lwgparse.o lwgparse.c
>>>>>>>>>>-DUSE_STATS
>>>>>>>>>>-o wktparse.tab.o wktparse.tab.c
>>>>>>>>>>wktparse.y: In function 'lwg_parse_yyparse':
>>>>>>>>>>wktparse.y:43: warning: pointer targets in passing argument 1 of
>>>>>>>>>>'alloc_wkb' differ in signedness
>>>>>>>>>>-DUSE_STATS
>>>>>>>>>>-o lex.yy.o lex.yy.c
>>>>>>>>>>lex.yy.c:3044: warning: 'yyunput' defined but not used
>>>>>>>>>>-DUSE_STATS
>>>>>>>>>>-o vsprintf.o vsprintf.c
>>>>>>>>>>-DUSE_STATS
>>>>>>>>>>lwgeom_pg.h:5:29: error: utils/geo_decls.h: No such file or
>>>>>>>>>>directory
>>>>>>>>>>lwgeom_pg.h:6:18: error: fmgr.h: No such file or directory
>>>>>>>>>>lwgeom_pg.h:28: error: syntax error before 'getGeometryOID'
>>>>>>>>>>lwgeom_pg.h:28: warning: type defaults to 'int' in declaration of
>>>>>>>>>>'getGeometryOID'
>>>>>>>>>>lwgeom_pg.h:28: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:35: error: syntax error before '*' token
>>>>>>>>>>lwgeom_pg.h:36: error: syntax error before 'box2df_to_box'
>>>>>>>>>>lwgeom_pg.h:36: warning: type defaults to 'int' in declaration of
>>>>>>>>>>'box2df_to_box'
>>>>>>>>>>lwgeom_pg.h:36: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:37: error: syntax error before 'BOX'
>>>>>>>>>>lwgeom_pg.h:40: error: syntax error before 'BOX2D_same'
>>>>>>>>>>lwgeom_pg.h:40: warning: type defaults to 'int' in declaration
>>>>>>>>>>of 'BOX2D_same'
>>>>>>>>>>lwgeom_pg.h:40: warning: parameter names (without types) in
>>>>>>>>>>function declaration
>>>>>>>>>>lwgeom_pg.h:40: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:41: error: syntax error before 'BOX2D_overlap'
>>>>>>>>>>lwgeom_pg.h:41: warning: type defaults to 'int' in declaration of
>>>>>>>>>>'BOX2D_overlap'
>>>>>>>>>>lwgeom_pg.h:41: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:41: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:42: error: syntax error before 'BOX2D_overleft'
>>>>>>>>>>lwgeom_pg.h:42: warning: type defaults to 'int' in declaration of
>>>>>>>>>>'BOX2D_overleft'
>>>>>>>>>>lwgeom_pg.h:42: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:42: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:43: error: syntax error before 'BOX2D_left'
>>>>>>>>>>lwgeom_pg.h:43: warning: type defaults to 'int' in declaration
>>>>>>>>>>of 'BOX2D_left'
>>>>>>>>>>lwgeom_pg.h:43: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:43: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:44: warning: type defaults to 'int' in declaration
>>>>>>>>>>of 'BOX2D_right'
>>>>>>>>>>lwgeom_pg.h:44: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:44: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:45: error: syntax error before 'BOX2D_overright'
>>>>>>>>>>lwgeom_pg.h:45: warning: type defaults to 'int' in declaration of
>>>>>>>>>>'BOX2D_overright'
>>>>>>>>>>lwgeom_pg.h:45: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:45: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:46: error: syntax error before 'BOX2D_overbelow'
>>>>>>>>>>lwgeom_pg.h:46: warning: type defaults to 'int' in declaration of
>>>>>>>>>>'BOX2D_overbelow'
>>>>>>>>>>lwgeom_pg.h:46: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:46: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:47: error: syntax error before 'BOX2D_below'
>>>>>>>>>>lwgeom_pg.h:47: warning: type defaults to 'int' in declaration
>>>>>>>>>>of 'BOX2D_below'
>>>>>>>>>>lwgeom_pg.h:47: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:47: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:48: error: syntax error before 'BOX2D_above'
>>>>>>>>>>lwgeom_pg.h:48: warning: type defaults to 'int' in declaration
>>>>>>>>>>of 'BOX2D_above'
>>>>>>>>>>lwgeom_pg.h:48: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:48: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:49: error: syntax error before 'BOX2D_overabove'
>>>>>>>>>>lwgeom_pg.h:49: warning: type defaults to 'int' in declaration of
>>>>>>>>>>'BOX2D_overabove'
>>>>>>>>>>lwgeom_pg.h:49: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:49: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:50: error: syntax error before 'BOX2D_contained'
>>>>>>>>>>lwgeom_pg.h:50: warning: type defaults to 'int' in declaration of
>>>>>>>>>>'BOX2D_contained'
>>>>>>>>>>lwgeom_pg.h:50: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:50: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:51: error: syntax error before 'BOX2D_contain'
>>>>>>>>>>lwgeom_pg.h:51: warning: type defaults to 'int' in declaration of
>>>>>>>>>>'BOX2D_contain'
>>>>>>>>>>lwgeom_pg.h:51: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:51: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:52: error: syntax error before 'BOX2D_intersects'
>>>>>>>>>>lwgeom_pg.h:52: warning: type defaults to 'int' in declaration of
>>>>>>>>>>'BOX2D_intersects'
>>>>>>>>>>lwgeom_pg.h:52: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:52: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:53: error: syntax error before 'BOX2D_union'
>>>>>>>>>>lwgeom_pg.h:53: warning: type defaults to 'int' in declaration
>>>>>>>>>>of 'BOX2D_union'
>>>>>>>>>>lwgeom_pg.h:53: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:53: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:55: error: syntax error before 'LWGEOM_same'
>>>>>>>>>>lwgeom_pg.h:55: warning: type defaults to 'int' in declaration
>>>>>>>>>>of 'LWGEOM_same'
>>>>>>>>>>lwgeom_pg.h:55: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:55: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:56: error: syntax error before 'BOX3D_construct'
>>>>>>>>>>lwgeom_pg.h:56: warning: type defaults to 'int' in declaration of
>>>>>>>>>>'BOX3D_construct'
>>>>>>>>>>lwgeom_pg.h:56: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:56: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:57: error: syntax error before 'BOX2DFLOAT4_ymin'
>>>>>>>>>>lwgeom_pg.h:57: warning: type defaults to 'int' in declaration of
>>>>>>>>>>'BOX2DFLOAT4_ymin'
>>>>>>>>>>lwgeom_pg.h:57: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:57: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:59: error: syntax error before 'LWGEOM_force_2d'
>>>>>>>>>>lwgeom_pg.h:59: warning: type defaults to 'int' in declaration of
>>>>>>>>>>'LWGEOM_force_2d'
>>>>>>>>>>lwgeom_pg.h:59: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:59: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:60: error: syntax error before 'LWGEOM_force_3dm'
>>>>>>>>>>lwgeom_pg.h:60: warning: type defaults to 'int' in declaration of
>>>>>>>>>>'LWGEOM_force_3dm'
>>>>>>>>>>lwgeom_pg.h:60: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:60: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:61: error: syntax error before 'LWGEOM_force_3dz'
>>>>>>>>>>lwgeom_pg.h:61: warning: type defaults to 'int' in declaration of
>>>>>>>>>>'LWGEOM_force_3dz'
>>>>>>>>>>lwgeom_pg.h:61: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:61: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:62: error: syntax error before 'LWGEOM_force_4d'
>>>>>>>>>>lwgeom_pg.h:62: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:63: error: syntax error before
>>>>>>>>>>'LWGEOM_force_collection'
>>>>>>>>>>lwgeom_pg.h:63: warning: type defaults to 'int' in declaration of
>>>>>>>>>>lwgeom_pg.h:63: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:63: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:64: error: syntax error before 'LWGEOM_force_multi'
>>>>>>>>>>lwgeom_pg.h:64: warning: type defaults to 'int' in declaration of
>>>>>>>>>>lwgeom_pg.h:64: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:64: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:66: error: syntax error before 'LWGEOMFromWKB'
>>>>>>>>>>lwgeom_pg.h:66: warning: type defaults to 'int' in declaration of
>>>>>>>>>>'LWGEOMFromWKB'
>>>>>>>>>>lwgeom_pg.h:66: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:66: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:67: error: syntax error before 'WKBFromLWGEOM'
>>>>>>>>>>lwgeom_pg.h:67: warning: type defaults to 'int' in declaration of
>>>>>>>>>>'WKBFromLWGEOM'
>>>>>>>>>>lwgeom_pg.h:67: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:67: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:69: error: syntax error before 'LWGEOM_getBBOX'
>>>>>>>>>>lwgeom_pg.h:69: warning: type defaults to 'int' in declaration of
>>>>>>>>>>'LWGEOM_getBBOX'
>>>>>>>>>>lwgeom_pg.h:69: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:69: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:70: error: syntax error before 'LWGEOM_addBBOX'
>>>>>>>>>>lwgeom_pg.h:70: warning: type defaults to 'int' in declaration of
>>>>>>>>>>'LWGEOM_addBBOX'
>>>>>>>>>>lwgeom_pg.h:70: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:70: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>lwgeom_pg.h:71: error: syntax error before 'LWGEOM_dropBBOX'
>>>>>>>>>>lwgeom_pg.h:71: warning: type defaults to 'int' in declaration of
>>>>>>>>>>'LWGEOM_dropBBOX'
>>>>>>>>>>lwgeom_pg.h:71: warning: parameter names (without types) in
>>>>>>>>>>lwgeom_pg.h:71: warning: data definition has no type or storage
>>>>>>>>>>class
>>>>>>>>>>liblwgeom.c: In function 'trim_trailing_zeros':
>>>>>>>>>>liblwgeom.c:158: warning: implicit declaration of function 'strchr'
>>>>>>>>>>liblwgeom.c:158: warning: incompatible implicit declaration of
>>>>>>>>>>built-in function 'strchr'
>>>>>>>>>>liblwgeom.c:163: warning: implicit declaration of function 'strlen'
>>>>>>>>>>liblwgeom.c:163: warning: incompatible implicit declaration of
>>>>>>>>>>built-in function 'strlen'
>>>>>>>>>>make[1]: *** [liblwgeom.o] Error 1
>>>>>>>>>>On 1/12/06, strk at refractions.net <strk at refractions.net> wrote:
>>>>>>>>>>>Please show some more lines - starting right before the *first*
>>>>>>>>>>>warning during make - after a make clean.
>>>>>>>>>>>--strk;
>>>>>>>>>>>On Thu, Jan 12, 2006 at 08:39:25AM -0700, Assad Jarrahian wrote:
>>>>>>>>>>>>I am talking about the latest release 1.10
>>>>>>>>>>>>Yes it seems that I can find postgres.h
>>>>>>>>>>>>pg_config --includedir-server
>>>>>>>>>>>>What should I do with it?
>>>>>>>>>>>>thanks.
>>>>>>>>>>>>-assad
>>>>>>>>>>>>>You're talking about postgis version ?
>>>>>>>>>>>>>Can you find postgres.h under `/usr/bin/pg_config
>>>>>>>>>>>>>--includedir-server` ?
>>>>>>>>>>>>>--strk;
>>>>>>>>>>>>>On Thu, Jan 12, 2006 at 01:46:17AM -0700, Assad Jarrahian wrote:
>>>>>>>>>>>>>>David and all,
>>>>>>>>>>>>>>Thanks. I got everything installed, but when installing
>>>>>>>>>>>>>>postgis I
>>>>>>>>>>>>>>got errors (see below).
>>>>>>>>>>>>>>The configure summary:
>>>>>>>>>>>>>>SUMMARY
>>>>>>>>>>>>>>HOST_OS: linux-gnu
>>>>>>>>>>>>>>PGSQL: /usr/bin/pg_config
>>>>>>>>>>>>>> GEOS: /usr/local/bin/geos-config (with C-API)
>>>>>>>>>>>>>> PROJ: dir=/usr/local
>>>>>>>>>>>>>>ICONV: 1
>>>>>>>>>>>>>>PORTNAME: linux
>>>>>>>>>>>>>>PREFIX: /usr
>>>>>>>>>>>>>>EPREFIX: ${prefix}
>>>>>>>>>>>>>>   DOC: /usr/share/doc/postgresql-doc-8.1
>>>>>>>>>>>>>>  DATA: /usr/share/postgresql/8.1/postgresql/contrib
>>>>>>>>>>>>>>   MAN: /usr/share/postgresql/8.1/man
>>>>>>>>>>>>>>   BIN: /usr/lib/postgresql/8.1/bin
>>>>>>>>>>>>>>   EXT: /usr/lib/postgresql/8.1/lib (\$$libdir)
>>>>>>>>>>>>>>and the errors:
>>>>>>>>>>>>>>declaration of
>>>>>>>>>>>>>>'getGeometryOID'
>>>>>>>>>>>>>>storage class
>>>>>>>>>>>>>>declaration of
>>>>>>>>>>>>>>'box2df_to_box'
>>>>>>>>>>>>>>storage class
>>>>>>>>>>>>>>declaration of 'BOX2D_same'
>>>>>>>>>>>>>>storage class
>>>>>>>>>>>>>>declaration of
>>>>>>>>>>>>>>'BOX2D_overlap'
>>>>>>>>>>>>>>storage class
>>>>>>>>>>>>>>declaration of
>>>>>>>>>>>>>>'BOX2D_overleft'
>>>>>>>>>>>>>>storage class
>>>>>>>>>>>>>>declaration of 'BOX2D_left'
>>>>>>>>>>>>>>storage class
>>>>>>>>>>>>>>lwgeom_pg.h:44: error: syntax error before 'BOX2D_right'
>>>>>>>>>>>>>>declaration of 'BOX2D_right'
>>>>>>>>>>>>>>storage class
>>>>>>>>>>>>>>declaration of
>>>>>>>>>>>>>>'BOX2D_overright'
>>>>>>>>>>>>>>storage class
>>>>>>>>>>>>>>declaration of
>>>>>>>>>>>>>>'BOX2D_overbelow'
>>>>>>>>>>>>>>storage class
>>>>>>>>>>>>>>declaration of 'BOX2D_below'
>>>>>>>>>>>>>>storage class
>>>>>>>>>>>>>>declaration of 'BOX2D_above'
>>>>>>>>>>>>>>storage class
>>>>>>>>>>>>>>declaration of
>>>>>>>>>>>>>>'BOX2D_overabove'
>>>>>>>>>>>>>>storage class
>>>>>>>>>>>>>>declaration of
>>>>>>>>>>>>>>'BOX2D_contained'
>>>>>>>>>>>>>>storage class
>>>>>>>>>>>>>>declaration of
>>>>>>>>>>>>>>'BOX2D_contain'
>>>>>>>>>>>>>>storage class
>>>>>>>>>>>>>>declaration of
>>>>>>>>>>>>>>'LWGEOM_getBBOX'
>>>>>>>>>>>>>>storage class
>>>>>>>>>>>>>>declaration of
>>>>>>>>>>>>>>'LWGEOM_addBBOX'
>>>>>>>>>>>>>>storage class
>>>>>>>>>>>>>>declaration of
>>>>>>>>>>>>>>'LWGEOM_dropBBOX'
>>>>>>>>>>>>>>storage class
>>>>>>>>>>>>>>'strchr'
>>>>>>>>>>>>>>'strlen'
>>>>>>>>>>>>>>make: *** [liblwgeom] Error 2
>>>>>>>>>>>>>>On 1/12/06, Stefano Costa <steko at iosa.it> wrote:
>>>>>>>>>>>>>>>Il giorno gio, 12/01/2006 alle 00.28 -0700, Assad Jarrahian
>>>>>>>>>>>>>>>ha scritto:
>>>>>>>>>>>>>>>>hey david and all,
>>>>>>>>>>>>>>>>thanks for replying.
>>>>>>>>>>>>>>>>I tried the first step and it raised an exception
>>>>>>>>>>>>>>>>sudo apt-get postgresql-dev
>>>>>>>>>>>>>>>>E: Invalid operation postgresql-dev
>>>>>>>>>>>>>>>You should add an "install" just like this:
>>>>>>>>>>>>>>>sudo apt-get install postgresql-dev
>>>>>>>>>>>>>>>Regards,
>>>>>>>>>>>>>>>Stefano
>>>>>>>>>>>>>>>Stefano Costa
>>>>>>>>>>>>>>>http://www.iosa.it Software Open Source per l'Archeologia
>>>>>>>>>>>>>>>Jabber: steko at jabber.linux.it
>>>>>>>>>>>>>>>GnuPG Key ID 1024D/0xD0D30245
>>>>>>>>>>>>>>>Linux Registered User #385969 counter.li.org
>>>>>>>>>>>>>>>_______________________________________________
>>>>>>>>>>>>>>>postgis-users mailing list
>>>>>>>>>>>>>>>postgis-users at postgis.refractions.net
>>>>>>>>>>>>>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>>>>>>>>>>>/"\    ASCII Ribbon Campaign
>>>>>>>>>>>>>\ /    Respect for low technology.
>>>>>>>>>>>>>X     Keep e-mail messages readable by any computer system.
>>>>>>>>>>>>>/ \    Keep it ASCII.
>>>>>>>>>>>/ \    Keep it ASCII.
>>>>>>>>/ \    Keep it ASCII.
